Rover 3500 V8 Oil Pressure Dependant Ignition
When rebuilding my RV8 on a test stand, I added a relay to inhibit the ignition until the oil pressure light goes out. This worked fine but yesterday I ran the engine up to temperature for the first time before turning it off. When I tried to restart it, the oil pressure light would not go out and therefore the engine wouldn't start. I'm wondering whether the hot oil means cranking alone doesn't achieve the minimum pressure. I'll try again later today when the neighbours are awake but I thought someone might be able to confirm they have seen this with their RV8?
