Results 11 to 20 of 22
    Cheshire
    51
    374
    I was going to say that these photos remind me of mine, but your before ones are much dirtier (which is saying something) and your after ones are much cleaner; very nice.
    3,778
    That’s a very satisfying set of photo’s!
    GD J1M
    301
    Quote Originally Posted by Grumbleweed View Post
    193bhp and 221lb-ft, see readout attached. No stump puller but happy with the gains I made with a higher lift cam, higher compression pistons, Edelbrock manifold and 4 barrel carb. Baby V8 but should still be fun and it was always planned to be a stepping stone for greater things! It was a complete baked, oily mess when I bought it for £50.
    Attachment 39174
    That's what you would get from a standard SD1 Vitesse, you can't moan at that.
    That car would do 0 - 60 in about 7.5 seconds, that was good back in the day in
    a fairly heavy vehicle.
    You have done a good job of getting rid of the nasty Black Death that was present.
    Also I would not have been suprised if the engine was a runner to start with ?
    575
    Aye, need to get mine on the Dino once I’ve sorted the ignition.
    Compared to a Vitesse, I’ve got another 400cc capacity, later injection, less material in the ports better ignition (hopefully once sorted) and free-er exhaust.
    Better be over 200BHPs
    301
    Same as you, I've got another 400 cc. I am using 270 2 Piper cam with Rhoads hydraulics, 4 barrel Holley with
    good flow headers and side pipes exhaust system.
    Have no clue of any dyno figures but this seems to work for me .
    I would have thought it should be giving around 220 BHP .
    Oct 2017
    Oxford
    1,008
    You should be very proud of what you have achieved.
    It is very satisfying to rebuild an engine yourself, good work!
    Apr 2016
    Cambridge
    165
    Thanks. Just hope it isn’t too long before it can be fired up again!
    575
    Out of interest what it the engine from? Looks like an early block, P6 or early RR?
    Is it runing later, larger port heads?
    What's the spec'
    301
    The heads look like SD1 type, as for the block, if it was an early P6 there would
    have been a rope crankshaft seal as apposed to the neoprene type.
    Block numbers would be 10a and SD1's, 11a .
    Apr 2016
    Cambridge
    165
    Its a 14 bolt 3.5 from an SD1. 11a block number.
    - Standard heads/ports. (skimmed to allow for composite head gasket)
    - Viper Hurricane cam
    - Re-bored with higher (10.5:1) compression pistons
    - Edelbrock performer manifold - 2198
    - Edelbrock/Weber 500 carb (i refurbished this but probably needs replacing at some point)
    Got LOADS more images of the build if you need/want to see anything specific.
    Thanks,
    Grumbleweed
