Results 11 to 20 of 20
    708
    Useful bellhousing that as you can access the clutch and centre bearing via the bottom plate which is removable.
    Yes, an FE is tight in a Dax but doable. My engine virtually touches everywhere! I even had to trim the inner skin on the bonnet to clear the air cleaner. Getting the exhausts out is a trial as well!
    The modern small staters are a godsend.
    4,908
    Indeed - the only place I have any room is up front, where (especially in a standard chassis) there would be acres of room.. well, relatively speaking!
    1,721
    Aaron,
    Do you have extended foot wellls? I have on mine which intrude into the engine bay. The back ports on the heads of my Cleveland are a tight squeeze.
    708
    Like this!
    Back as far as it can and still allow the oval air cleaner to fit (mind you, any further and number 4 and number 8 exhausts would be inside the cockpit!) Fits exactly heightwise, air cleaner barely clear of the bonnet and the bellhousing just about able to clear a speed bump. No tolerance at all. This is in an early DAX chassis.
    This is quite an old picture actually. I have since taken the choke towers off the carbs, put 'new' (as original 6090D) heads on it, new expansion tank and cleaned it all up a bit. Used an acid wash to clean the inlet manifold and it came up really well (as you can see it needed it).
    Getting the headers out is a pain, especially on the drivers side, where you have the starter and the steering. As for getting the starter off, I highly recommend a removeable panel in the drivers footwell otherwise it is hell!
    1,721
    Chris,
    I like the twin carbs and red colour covers look.
    Photo is very low resolution (11.4 KB size of a postage stamp so cannot zoom in on the headers lol
    John Desz
    Essex & Herts Area Rep. UKCC
    708
    Chris,
    Sorry about the pic. For some reason I cannot upload the picture in a decent format. The original is wider too and shows the fit better. If you want to see it just PM and I'll email instead. No idea why it's being a pain. Better still I'll take a more recent one showing the tidying up with the new heads etc!!
    708
    Chris,
    Try this
    1,721
    Thanks Chris nice photo. It can be challenging to upload photos.
    1,721
    Thanks Chris
    Maldon Essex
    548
    Bloody hell, there really is not much room left in there! Well at least you can't drop a spanner down the side of it. And I thought mine was looking like a tight squeeze!
