    Oct 2014
    United Kingdom
    52
    397
    Speed sensor replacement - driveshaft ring
    Ok - next little job to sort is an intermittment fault with the speedo - it just drops to zero!
    Think we have tracked it to magnetic ring on the propshaft. It is a Smith guage. The sensor seems to be fine but the magnetic ring is deformed and the gap varies from by over 4mm - I believe it should be a constant 0.8mm.
    The orignal builer has clearly taken a grinder to it before fitting. My engineer did not like my idea of just bonding the magnets to the prop!!
    I can't seem to get any details of this part or where to find a replacement. Anyone recognise it or any suggestions?
    1,523
    Split collar magnetic pick up
    https://www.ebay.co.uk/itm/Haltech-D...sAAOSwNntgCakl
    Holley do one which is a lot more from USA. Tax and shipping.
    I would use a pick up and pick up the bolts off the prop
    You might get this to work as alternative 50mm shaft 4 pick up. They use these on karts.
    https://www.demon-tweeks.com/alfano-...E&gclsrc=aw.ds
    1,523
    They do a 50mm but does not state the pickups. Its not split collar is only down side.
    https://www.aimshop.com/products/aim...SABEgKtlPD_BwE
    Oct 2014
    United Kingdom
    52
    397
    There are some 2" (51mm) split shaft collars on eBay at the moment.
    https://www.ebay.co.uk/itm/2-ID-Spli...t/154212597768
    The prop shaft is 50mm and the magnets are easy enough to drill and fit so I have ordered one of these to play with - seems a more Yorkshire approach than the £70 option from Haltech which would also work.
    1,523
    That looks a good option . Always look at the most cost effective route. Those split collars look well made.
    Some careful drilling and placing of the magnets.
    Oct 2014
    United Kingdom
    52
    397
    Arrived. Needed the bolts machining down a bit as they were slightly proud of the ring but simple enough - also easy to drill and fit the magets and now have a stable and working speedometer .
    Great and cost effective solution which now fits as it should.
    1,903
    Quote Originally Posted by david.mt View Post
    Looks neat and I suppose will prevent the usual problems of magnets flying off the prop. Presumably you used 4 equi-spaced around the ring and araldited into the drilled holes?
    Oct 2014
    United Kingdom
    52
    397
    Quote Originally Posted by Dek View Post
    Yes bonded in but only 2 magnets in the original. I believe the speedo is based on pulses per mile so should work with any number of magnets. I am hoping that as the original had 2 magnets and the replacement now has 2, the speedo should remain calibrated.
    4,616
    Interesting alternative to the "usual" bolts-on-the-diff approach. I wonder how much lateral movement your prop shaft sees? Presumably you have stiff engine & gearbox mounts to limit the movement - that was my first thought, anyway. Other than that, probably more reliable than making sure all the bolt heads face the same way etc?
