On the GD there are angle brackets which bolt to end of the fulcrum pins front and rear, these then bolt onto the chassis which "wraps" over the diff' which also has a mount for the 4, taper seat, bolts at the top of the diff. Not too different from your diagram. Easy enough when the body's not on.
