Results 1 to 7 of 7
    Nov 2004
    Portsmouth, Hampshire
    484
    soft top / tonneau studs
    Quick question. When fitting the soft top/tonneau studs are people using the self tapping type or threaded with a nut ? Im thinking a nut is much better but probably far more painful to fit in some spots !
    Apr 2014
    Stourport on Severn
    309
    Nuts are more fiddly but I was advised the self tapper ones could cause splits, so I went with nuts.
    Jun 2014
    Swansea
    177
    Hi Paul
    I used the nuts on both my soft top and tonneau. As Steve said the self tapper ones can cause splits in the fiber glass.
    Rob
    Rob
    AK Gen I - 4.6l Rover V8, Stage III heads, MC1 cam
    On the road March 2019
    709
    ^^^^^^^^Wot that lot said!^^^^^^^^
    A nut backed stud will never pull out unless you're an absolute gorilla. If a self tapped stud should pull out it will just cause damage that will be a pain to hide.
    I was very surprised way back in the day on A Car Is Born that self tapping studs were used in the Pilgrim Sumo that was being built.
    David.
    Wessex region caretaker rep.
    2,369
    I used self tapping studs without an issue, but you MUST countersink the hole before you screw the stud in. It's the gel coat that will crack rather than the fibreglass, counter sink the hole takes the gel coat off the stud threads.
    Jul 2007
    peterborough
    275
    Studs every time.
    Jon
    AK
    Nov 2004
    484
    sticking with threaded studs by the look of it which was plan 'A' !
