Results 1 to 6 of 6
    May 2020
    west sussex
    39
    Pilgrim weights IVA?
    I have done everything today attempting to find the ORIGINAL design laden weights for Sumo 3.
    I have searched internet, Pilgrim manual, this forum etc etc.... nothing?
    I found the Dax max weights front 620kgs rear 820kgs.
    IVA form needs axle weights 1-2-3, gross weight, Train (whatever that is?) and towable mass?
    Can anyone help, spent most of today just trying to fill out IVA application form, got to page 4... only 8 more pages to go
    Now I don't think I'm a stupid person, I spent a day completing Power Of Attorney applications that solicitor wanted £800 to do, but this IVA application is a pain in the backside.
    2,995
    Have you tried giving Pilgrim a call??
    1,925
    Taken from my IVA Individual Approved Certificate (IAC) for my Sumo Mk3 with Rover V8 engine.
    Section 2:
    Para. 13
    Mass of vehicle: 1055
    Maximum GVW in UK: 1250
    Para 16.1
    Technically permissible max laden mass: 1250
    Para. 16.2
    Axle 1: 600
    Axle 2: 650
    Axle 3: N/A
    Axle 4: N/A
    Para. 16.4
    Technically permissible max mass of the combination: 1750
    Para 18
    Maximum towable mass or max UK GTW: 500
    All above in kg, hope this may be of some use.
    Take care,
    May 2020
    west sussex
    39
    Quote Originally Posted by Ian C View Post
    Section 2:
    Para. 13
    Para 16.1
    Para. 16.2
    Axle 1: 600
    Axle 2: 650
    Axle 3: N/A
    Axle 4: N/A
    Para. 16.4
    Para 18
    Take care,
    Thanks Ian, those figures should be correct to use, the actual laden weight will be slightly heavier as I have a SBC engine
    9,389
    I would call Pilgrim so you have the right numbers - the SBC is significantly heavier than a RV8.
    Nov 2013
    My Garage
    998
    I've called Pilgrim twice since this last crowd took over, both times they were totally unhelpful
    I wouldnt bother any more
    MKIII Pilgrim Sumo. 3.5 Litre Rover V8 Towing an Eriba Puck Caravan
