Results 1 to 4 of 4
    May 2014
    Sutton Coldfield
    15
    Jag Driveshaft - Inner hub Seal Track?
    In process of building up Jag rear end on my GD. Wards refurbished hubs. Had a note with hubs stating Seal Track should not spin on driveshaft, mine does. I note the part number for the Inner hub seal track (CCC6807) appears universal across all types of jags. What's others experience of this, tight or loose fit?
    http://i.imgur.com/GD4NDHJ.mp4
    Mike
    Mike
    GD Jag MKIV...well chassis for it
    662
    Must admit I've no personal experience with this (didn't even realise that was a separate part) but surely that part is going to be clamped tight when hub is all tighened up so shouldn't be a problem? Obviously shouldn't rattle about on the shaft or there would be a good chance of not running concentric.
    May 2014
    Sutton Coldfield
    15
    Thanks for the response. In interim emailed Wards they said solution is to use a good Loctite/Bearing fit
    Mike
    Nov 2016
    Stevenage
    333
    Yes ditto, mine were tight on car 1, but loose on car 2, for reasons unknown so locktited on as per ward
