    Feb 2002
    flitwick, bedfordshire, england.
    73
    paint prep & coolant questions
    have been looking at re-paint on my dax & have had some good info from the forum directly (cheers wilf) & looking at other peoples posts,question I have is whats the best method for removing paint.So far I have been told you can either sand,use chemicals or chisel it off? I'm not doing it myself but would like to know so I can have some input when talking to the painter. Also recently installed new ally heads, water pipe kit,Ally rad (dax) etc etc. Read in a manual you should not add antifreeze initially as ally heads are porous but instead add inhibitor then change after 2000 miles,spoke to brian at repower who supplied the bits he said doesn't matter either way,would like your input.Finally, I am hoping to go to the dax open day on friday & look forward to seeing some of you there, have lots of questions to ask(to silly to post) & hope to see some top cars.I spoke to gary at dax who agreed to test drive my car, as I haven't driven another cob I don't know how it compares. Just thought, I had to remove nose mesh could I damage rad if drive without it ??
    Finally,Finally dave enjoy your build pics etc hope to see you friday
    cheers
    Lardy
    Jan 1999
    Northampton, Northampton, UK.
    9,180
    RE: paint prep & coolant questions
    Prolonged exposure can eat the ally, depending on whether you have an electrolyte to start the chemical process.
    You need to check what other parts have gone into the engine and if one of them will react and start the chemical process, if they will you can buy a sink which will inhibit the electrolytic process.
    I ran antifreeze in my engine from day one with Barrs fluid also with no problems, and looking at the engine over the winter, there were no side-effects. The anti-freeze isn't the issue, it is the chemical reaction of disparate metals.
    Robert
    Forum Admin
    http://www.cobraclub.com/flags/UK.gif
    Best Regards
    Robert
    Feb 2002
    73
    robert thanks for the quick reply,whats barrs fluid ?
    Jan 1999
    9,180
    It stops leaks in cooling systems, lubricates pumps and generally keeps things in good shape.
    Robert
    Forum Admin
    Best Regards
    Robert
    STOKE ON TRENT, U.K.
    10,167
    Okey dokey.
    ‚ÄčPro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Low Volume manufacturer of
    OEM style stainless SIDEPIPES
    Jan 2001
    On the naughty step
    13,798
    Yep - a good antifreeze and "Bars-Leaks" is what works for me too. The question of electrolytic corrosion is relevant, since we have a mixture of metals in the cooling corcuit with differing electolysis potentials. Since cars with iron blocks/ally heads/copper&brass&?? radiators have been around for yonks, I guess it can't be too bad. I thought a good antifreeze was also anti corrosive as well? Not sure.
    PS - you can get Bars-Leaks in liquid or solid (you crumble it in) form - either works.
    Wilf
  1. Coolant
    By fiona in forum General Cobra Discussion
    Last Post: 20-06-06, 11:32 AM
  2. Coolant hoses RV8
    By Phil McCann in forum Pilgrim Sumo Technical Questions
    Last Post: 30-04-04, 09:43 AM
  3. Best book for bodywork prep ?
    By STEVE W in forum General Cobra Discussion
    Last Post: 19-11-03, 11:36 AM
  4. Coolant Woes
    By David Parkes in forum Pilgrim Sumo Technical Questions
    Last Post: 10-11-03, 10:00 AM
  5. Getting Coolant into the System
    Last Post: 05-11-03, 09:59 AM
