Results 1 to 7 of 7
Thread: Tyre pressure
    Dec 2019
    amersham
    273
    Tyre pressure
    I.ve got 245/17 tyres all round and just need some advice on what sort of tyre pressure may be needed, the kits an AK with small block chevy and jaguar donor axle so its fairly conventional weight wise. Perhaps its a case of trying a few pressures to see how the kit drives or is there a more scientific approach ?.
    Any recommendations.
    2,040
    Quote Originally Posted by methoni View Post
    The more scientific approach is to use a laser thermometer. Get the tyres warm and measure the temperature at the inner, middle and outer aspects of the tyre. At the correct pressure there should be an even contact patch with the road across the width of the tyre and hence an even temperature. Over inflated temperature will be higher in the middle. Under inflated temperature will be higher at the edges.
    Houghton le Spring
    203
    I have a Dax with SBC. 235/45x17" front - 255/45x17" rear.
    Have always tended to run around 17-18 psi front and rear.
    Went touring in Scotland a couple of years ago - 3 weeks & ~2k miles. Had the rears at 20 psi for that (extra luggage) - and left it at that since. Just had cause to remove rear tyres and they have been wearing more in the centres - so would suggest 17/18 psi would be a good starting point for you.
    Geoff
    Dec 2019
    amersham
    273
    Thanks Geoff
    As you say 17/18 psi seems a good starting point, under pressure particularly on the front and the steering may be heavy so its a case of either increasing or decreasing the pressure.
    Apr 2014
    Stourport on Severn
    306
    245/17 on the front ?
    make sure you check tyres don’t foul the inner wings on full lock.
    Dec 2019
    amersham
    273
    Have checked the clearance on full lock and its about 25 mm on the inner wing, i could increase that a bit by cutting back the lower lip of the inner wing but it does clear so i think i will leave it.
    Good advice though.
    ps i will also check it with a trial run and again when the tracking has been done.
    Jul 2007
    peterborough
    274
    22psi front , 24psi rear.
    Jon
    AK
