Results 1 to 10 of 17
    Feb 2013
    431
    Jag IRS Question...
    I always try to Google this stuff first, but I really can't seem to shed any light on this one.
    It's about my IRS rear shock mounting spindles/shafts. They're approx 11.5mm dia. Other folk seem to have shafts that are 5/8". Anyone know why? Can the spindles/shafts be swapped for the larger ones if required?
    Advice appreciated guys.
    2,524
    Not sure I fully understand the question. Sounds like the ones you have are 7/16" so they must have used both sizes over the years. Maybe the smaller ones under a lighter car. I presume you would have to swap the lower wishbones to go for the larger bolts but I'm not sure why you would want to under such a light car.
    Have I got the wrong end of the stick?
    Feb 2013
    431
    I was asking because I've seen shocks for sale which have a 5/8" ID bush top and bottom, but on my car they are 7/16". I'm thinking I could fit sleeves to the spindles to make them up to 5/8". I'll take a look at mine again later...
    509
    Don't know if this will be any help, on the early Southern Roadcraft with Jag i r s the rear top bushes were taken
    from the original rear shocks and used in conjunction with the new fronts .
    Feb 2013
    431
    Wow, it's humid today - after much sweating and grunting, I now know that my mounting spindles are shouldered - 5/8 through the axle and reduced to 7/16 at the ends. They're also removeable so I can swap them out. Even if I can't find a 5/8 set, I can get them machined. Any suggestion where I can buy a set?
    10,400
    SNG Barrett amongst others.
    https://www.sngbarratt.com/English/#/uk/home
    Maldon Essex
    549
    Mine are shouldered, I made sleeves, there is no weight on the back of these cars so sleeving them would be fine, the car ran for years with no problem using them anyway.
    Feb 2013
    431
    Yeah, I'd be ok with that. I'm still confused though. Were some spindles 5/8 from standard? If so, I could try to get a set. Still searching...
    Maldon Essex
    549
    Sorry, I don't know the answer, just decided to use what I had as I felt that the lightest car they could have come from was an e-type and that's still much heavier than the rear end of a Cobra.
    Feb 2013
    431
    I was over-thinking this one. I've ordered 1000mm steel bar, 5/8" dia. Cut into four 250mm lengths, get an M12 thread cut on each of the ends, job done. Cheap and easy!
