Results 1 to 10 of 12
    Feb 2013
    418
    Low-friction Throttle Cable - How to....
    I've just made my throttle pedal much lighter, thanks to advice from somebody on here whose identity I cannot recall. I replaced my standard 'bicycle-brake-cable' type outer, with a Teflon-lined, steel-braided, outer cable. I also shortened it, to eliminate an unnecessary 'S' bend which just didn't need to be there. An amazing improvement, so easy to do. De-grease your inner cable, then replace the outer with the following components:
    https://www.ebay.co.uk/itm/162226131285 This is the outer cable material. (I bought 2 metres)
    Venhill Engineering Ltd: SKU: FT4SN or SKU: FT4LN These are the ferrules which I chose.
    All of this took only 20 minutes or so to install. I was also able to install a weaker return spring on the carb, due to the reduced drag in the cable run.
    Total cost: Approx £13.
    You won't find the ferrules on eBay - go straight to Venhill.
    This was such a great and easy upgrade. Enjoy!
    251
    Pleased it worked for you, the difference is night and day isn't it.
    Baz
    708
    Perfect. Might give that a go myself
    Feb 2013
    418
    AKBaz - it was your idea, yes - brilliant indeed. Absolutely eliminated my heavy throttle linkage. couldn't recommend it more highly - thank you.
    Maldon Essex
    548
    Thanks for this. Already used Venhill when I made up a new handbrake cable but getting to the point of needing to make up a new throttle cable now.
    2,018
    So 3mm ID is not too large? What inner cable did you use? A standard bicycle one?
    Feb 2013
    418
    My inner cable is 2mm. is very nice size...
    2,018
    Is that standard bike size? Been a while since I changed one!
    Feb 2013
    418
    I don't know if it's a standard size - I can't really recall. It is, nonetheless, perfect for the job. Hope this helps!
    2,018
    Certainly does. Cheers!
