Results 1 to 7 of 7
    Jun 2016
    Germany
    Adapter plate for LT77 gearbox to Ford V8
    Hello,
    does anybody know suppliers where an adapter plate or an adapter bell housing for a LT77 gearbox onto a Ford V8 engine are available?
    Thank you for any help in that.
    kind regards
    Markus
    Mar 2005
    1,237
    Hi Marcus, are you sure the LT77 is strong enough for a Ford V8 ?
    David (AKA Firestarter29)
    9,603
    What David said.
    If its not too powerful an engine I would suggest either T5 World series (available from Real Steel),
    or if you can live without 5th gear, then a toploader.
    Then here is the popular Tremec offerings for more ££££...I mean Euros.
    9,651
    What David said.
    Don't forget the popular getrag box from either an old Jag or BMW but be careful of the BMW version as they do not all have a detachable bell housing.
    Jun 2016
    Germany
    Thanks to all. Sadly I haven’t got what I was asking for.
    Gearbox, propeller shaft, differential, everything fits right now and seem to be strong enough.
    It is just how to connect a Ford 302 or similar to the LT77. This would be the smallest possible invest.
    10,382
    What engine do you actually have?
    Confused by your comment "Ford 302 or similar"?
    If you have a small block Ford already it's going to be easier to change the gearbox for a T5WC and prop-shaft in my opinion.
    1,725
    If you have the LT77 Vitesse version this has larger bearings and stronger.
    Mating it to a Ford 302 might not be your best option. You can pick up a Getrag 260 in the E30 325i and as your in Germany will be easier to find.
    Ford 302 matched to a LT77 bellhousing will be very rare fined and might cost you a lot in the long run. I would sell the LT77 if its in good condition and you might pick up a Getrag for the same price or look at
    Supra Turbo boxs were used on a lot of RAM built cobra and they do an uprated bearing kit. Another route you could go.
    The 5-speed R154 uses the same bolt pattern as the Jeep AX15.
    Advance Adapters makes an adapter plate to connect a Jeep AX15 transmission.
    John Desz
    Essex & Herts Area Rep. UKCC
