Results 1 to 9 of 9
Thread: Cooling system
    Jul 2021
    Warwickshire
    3
    Cooling system
    Hi All.
    First post for me here.
    I sadly need a new Radiator for my Sumo Mk2 3.5 Rv8 (Any suggestions welcome, links and advice).
    Parts info and advice?
    Access and replacing the radiator on the MK2???
    At the same time I’m looking replace all hoses ( Again welcome some thoughts and links, advice and experience).
    Coolant: water mix or waterless?
    I have a duel fan set up.
    Thanks all
    Jan 2015
    Paignton Devon
    496
    I used a rad for a Ford transit 2,5 diesel, never had any cooling issues, I also have twin fans but I dont think the second one has ever had to kick in even in hot weather traffic, just normal water/antifreeze mix, I found that rad slim enough to slide over the top of the top chassis brace...just...made my own top braces to the rad
    Roger
    Jul 2006
    Worthing, West Sussex
    75
    Our Pilgrim is Chevy engine and I replaced the old Sierra radiator 18 months ago with a new one from these guys:-
    https://www.coolexperts.co.uk/
    I sent them the old rad as a pattern.
    However as the new rad 50mm it wouldn't slide over the top of the chassis.
    I cut an access hatch into the offside inner wheel arch and withdrew the rad from there, slid the new one in, very easy.
    This also gave easy access to three of the four rad-hose connections.
    Top brackets were home made.
    Twin fans were fitted by Coolex and I fitted a twin sensor fan switch to stage the fan switch on, don't think it's ever got hot enough (in UK driving this year) to switch the second fan on.
    I bought replacement hoses from Pilgrim, but had so much trouble with them ballooning up, that I went and bought a selection of blue silicon hoses and fitted them instead, no trouble with them.
    Coolant is 50/50 mix of distilled water and orange anti freeze.
    Hope this is of use.
    Regards, Don
    Apr 2016
    Cambridge
    217
    Jul 2021
    Warwickshire
    3
    Thank you. That’s been a great help.
    Jul 2006
    75
    I see the eBay one has the fan mounted with the through the radiator fixings. These fixings are what started the leaks on our old rad. As they vibrate slightly during driving, they slowly wore holes in the cores. Our new rad has welded on brackets and has 50mm core as I mentioned.
    New Radiator.pdf
    A Sierra rad is still going to be 30mm core. Our rad was about £50 more expensive that that one eBay, maybe the seller will take an offer.
    Jan 2015
    Paignton Devon
    496
    https://photos.app.goo.gl/oAfiu3TTnc94o2N99
    That's mine installed, fans are bolted to the edge flange and some brackets, it was only one of the regular rads nothing special, cost about £100
    https://www.ebay.co.uk/itm/293384285...YAAOSwXeteRVuM
    1,721
    The minimum should be a 50mm aluminium for a v8 , as the water volume is almost double which is what you need to shift the heat from the block. A 30mm will struggle big time and not be enough. Your fans will always be running.
    I run a 75mm copper rad and total system volume is 3 1/2 gallons ! My fan brings down the temperature and switches off even in traffic .
    Jan 2015
    Paignton Devon
    496
    Without measuring it as far as I can remember mines 40mm thick, the fans are controlled by a x-fan twin sensor on the bottom hose return to the engine, ( that's a whole different discussion!), first fan on at 93 off 88 second on 97 off 92, as I say don't think the second has ever been on, I do have ducting from the nose to the rad and that reduced driving temps by about 5' and reduced fan running time in traffic, fan running time isn't excessive
