Results 1 to 10 of 17
    Dec 2004
    Horley surrey
    87
    Failed MOT on emissions
    Hi all can anyone recommend a garage near Gatwick that can sort out the emissions on my pilgrim sumo it has a 1980 rover 3.5 sd1 engine with a high lift cam and a edelbrock 1404 carb. It failed on the emissions on high HC. The co's were fine. It does struggle to pass every year, just scrapped through last year.
    Keith
    Oxfordshire
    70
    1,748
    Keith,
    High HC levels are caused by unburnt fuel in the exhaust. In my experience this is usually due to an ignition fault/misfire, so check the usual things - low tension side wiring, coil, HT leads, plugs, etc.
    Good luck.
    Alan
    Dax 427 DeDion - now sold
    Apr 2014
    Stourport on Severn
    309
    What idle speed are you set to?
    There’s a big difference between HC readings on mine between 850 and 1000 rpm.
    Dec 2004
    Horley surrey
    87
    Quote Originally Posted by conrod View Post
    Keith,
    Good luck.
    Hi Alan, thanks for the reply, I will check leads plugs etc, but when I drove it to the MOT today it seemed to run fine no missing or anything and I took the long way round to the garage to try and clear the cobwebs, maybe were it has had lack of use this year!
    Keith
    Dec 2004
    Horley surrey
    87
    Quote Originally Posted by Peaches94 View Post
    Hi Steve,
    Idle speed is around 1000rpm
    Keith
    Apr 2014
    Stourport on Severn
    309
    On the idle speed, if the CO is ok, I believe they can run engine up to 2000 for the HC reading to achieve a pass.
    Dec 2004
    Horley surrey
    87
    Cheers Steve, yes CO is fine don't know what rpm they checked it on.
    Keith
    May 2005
    Sheffield
    1,051
    I thought ‘kit cars’ were visible smoke only. Is it more complicated than that?
    Nuf Said
    5,002
    Quote Originally Posted by nuf_said View Post
    The emissions test is as per the test in force at the time the engine was originally manufactured, so in other words - it's only 'visual smoke' if the engine fitted was made before 1975 (or 1987 if, for some reason, you fitted a rotary engine). 1975-1986 gets 4.5% CO & 1200ppm HC, 1986-1992 gets 3.5% CO & 1200ppm and after that it gets a bit more complicated with some years requiring a CAT test - there's a set of flowcharts in the IVA manual about it.
    May 2005
    Sheffield
    1,051
    Thanks. Good stuff to know. I just recall my old MOT tester saying visual smoke only for all kit cars. When I said the same to the current tester he said yes, visual smoke only, but I noticed he still shoved the probe in the exhaust.
