Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Thread: CLUTCH problem
  1. #31
    4,951
    Was the replacement gearbox dialled in properly for concentricity? If it were far enough out then the input shaft could be dragging on the pilot bearing/bushing - that would make it hard (or impossible) to select gears with the engine running.
    The other thing that came to mind was a pressure plate stuck to the flywheel - that usually only happens if the car is sat laid up for a long period, though
  2. #32
    812
    Beat me to it, partially seized clutch or broken spring/springs on the pressure plate caused by too much welly trying to "unstick" the clutch. If it's really stuffed, a combination of both.
    Graham.
  3. #33
    May 2020
    west sussex
    124
    Quote Originally Posted by Gatwick Axe Man View Post
    Graham.
    Yet to remove gearbox as my Healey 3000 restoration project is taking up garage space at the moment, so Cobra under a cover outside.
    But thoughts are it could be pressure plate spring falling and jamming, when I removed fork and tapped pressure plate there was a rattle?
  4. #34
    9,653
    If it's getting harder to change gear and now you are unable to get reverse it sounds a bit like it's not dialled in correctly and will be destroying your spigot bearing. This is what happened to me when I had a similar problem. As said though it could be that you haven’t got enough movement on the slave cylinder.
  5. #35
    May 2020
    west sussex
    124
    Quote Originally Posted by TINKA View Post
    No slave cylinder, just cable.
  6. #36
    May 2020
    west sussex
    124
    What clutch is best with a SBC 5.0 engine and Rover R380 gearbox, has anyone got same set up.
    I know the clutch wasn't changed when the R380 box was fitted to replace the LT77 box.
  7. #37
    8,570
    11" or 11 1/2" Chrysler clutch plate (it has the required 23 splines) and a chevy clutch cover to suit your flywheel. RealSteel used to do a kit especially for rover boxes on Chevy engines.
    BIG TONE
    Mercedes SL owner, definitely NOT a kitcar owner like you lot!
  8. #38
    May 2020
    west sussex
    124
    Quote Originally Posted by tonym View Post
    Thanks for info, I will contact RealSteel Monday
