    Dec 2011
    Rugby,West Midlands.
    771
    Billet aluminium thermostat housing
    As some of you know, my SBC chrome plated thermostat housing developed a hole and started peeing out water on the way to the Pistons and Props show. So I have been looking for a Billet Aluminium version, as these are better quality and wont corrode on the inside ,but the only Billet Aluminium versions I can find are the “Swivel” type which either have the outlet pipe set too high or tilt up at the wrong angle to line up with my coolant pipe.
    So does anyone know where I can get a Billet version that matches my existing one.
    This is my leaking "rubbish" housing .
    Paul.
    805
    Summit?
    This any good https://www.summitracing.com/parts/bsp-90320
    Worth trying Brian at Roadcraft first
    Dec 2011
    771
    Summit?
    I did find that "Swivel "one, but the outlet is higher up ,so it will not line up with the hose.
    Richard at Stateside Autos reckons you cannot get a non swivel "Billet" version identical to mine, but he has sent me some photos of a couple he has in stock , one is the same as the one you found on summit, but he reckons he can get a sbc OEM "fixed" good quality cast aluminium identical version to mine. He also said that he has had a lot of customers having corrosion issues with the after market chrome housings like mine ,but no issues with the sbc OEM cast alum ones.
    I will give Roadcraft a ring if Stateside Autos cannot get me the OEM version.
    Paul.
    3,057
    Hi Paul,
    Was looking for something similar myself recently - wanting one with a 1/4" NPT fitment for temp probe, but came across a few examples on ebay of normal ones without the 1/4" fitting
    https://www.ebay.co.uk/itm/221857930428
    https://www.ebay.co.uk/itm/221877021736
    for example
    rgds
    Gary
    Dec 2011
    771
    Thanks for the links Gary.
    I may have to go for something like the one in your 1st link ,if i cannot get the OEM version from Stateside Autos.
    The chrome housing in your 2nd link is exactly like the replacement i fitted two years ago, which has corroded and now leaking, so having had two after market chrome housings, i would advise anyone to stay away from them.
    Paul.
    3,057
    Sorry Paul, didn't fully read the 2nd one - so missed the chrome bit - doh!
    The seller of those two is the same and they have a few others too.
    first one should be ok though, iirc i've got a billet ally one that swivels and it's been on since 2006 when engine was built and hasn't leaked, as yet
