David re ECU mounting - you mention it’s mounted ‘on the top surface’ of the footwell. Not sure from the comment but it should not be mounted horizontally, should be mounted vertically with the heat sink fins top to bottom so as the ECU heats up (even from normal internal component warming) air can rise through the fins ‘bottom to top’ to cool the unit.
G
