Results 11 to 11 of 11
    Sep 2021
    Bridgwater, Somerset
    87
    From what I have read, the corvette sump came with a heater option for cold weather, you just plugged it in and it warmed your oil for cold starts.
    Loads have removed the heater and connector, then then fitted an adaptor and there oil temp sensor in its place. Others have gone with your suggestion, and drilled out the oil filter cross over housing and fitted there oil pressure sender in it. So it seems like we are spoilt for choice, If I can find a spare oil crossover blanking plate, I will drill and tap it and fit my my oil temp sender in it, then leave the sump alone.
    Also found this.
    Far Left.
    97-2000 Corvette OFAC (still available) Part Number 12551587
    Comes already drilled and with a metric thread M12 x 1.5
    Drill out the metric thread using a 7/16" drill
    Tap 1/4 pipe thread
    Use a 1/4" male x 1/8" female reducing bush
    Screw the 1/8" pipe threaded sender into that.
    Centre
    Fbody OFAC (No Longer available from GM new**) Part Number 12551595
    Comes blank (not drilled and no thread)
    Drill out the boss using a 21/64" drill
    Tap 1/8 pipe thread
    **Part superceded by 12577903
    Right
    GTO OFAC Part Number 12577903
    Drill the centre using a 21/64" drill
    Tap 1/8 pipe thread
    Screw in a 90 deg 1/8 pipe male female elbow
    Last edited by Mike424u; 30-11-21 at 10:34 AM. Reason: Additional information added
