Does the adapter have a manufacturers name on it? Try them direct? Lexus owners club or forum may help??
Also If the leak is coming through the bolt holes try dowry seals under the bolt heads.
Lee
Hi, Looking for assistance to clear my thinking on O ring seals. The problem I have is trying to seal the adapter plate, which replaces the Filter Bracket Assembly on the 1UZ engine, to allow the use of a remote filter.
The standard 1UZ Filter Bracket Assembly mates to a flat face on the engine and uses a gasket to seal the flow & return orifices. The gasket is in the shape of an "8" with a hole for the flow and a separate hole for the return in the same gasket. The adapter plate, which allows the fitment of a remote filter (see picture), has separate annular grooves around each orifice and came with rubber O rings. There has been a slight weep of oil from the joint between the adapter plate and the engine since it was first run so I decided to try and stop it by fitting new O rings.
The adapter plate was bought via an internet auction site and the vendor is unfortunately no longer traceable so no information on the size or nature of the O rings was available. After some research on how O rings work I bought O rings of the nearest suitable size (see picture for details) and fitted them with only a smear of vaseline to hold them in position during the fitting of the adapter plate. You will probably already have guessed the outcome - the leak is worse than before & I am now questioning my "understanding" of how an O ring works.
Can any one advise what size O ring is required to seal a flat surface to an annular groove measuring 2.96 mm wide by 1.32 mm deep and also whether any additional sealant material should be used.
As always any advice or suggestions will be gratefully received.
Ian
Lee
Lee,
Thanks for the reply. No unfortunately not, I think the adapter plates were made by a number of small manufacturing operations and I have seen numerous examples all broadly similar. Fairly sure the leak is emanating from the joint between the adapter plate and engine but good idea to seal the bolts, thank you.
Take care,
Ian
No exact match here but it looks like about 1.8mm dia maybe? https://www.allorings.com/o-ring-groove-design-metric
Groove dimensions are very specific in theory .. I think in practice most places just make one "about right"!
I've used speedflow who helped me with my take off plate when I had O ring issues, I think you may have to keep buying similar size O rings from suppliers that specifically deal with one's that can handle the temperatures of hot oil. The diameter of the holes is not an issue but the diameter of the ring is key sealing the orifices. Try till you seal I'm afraid!
Good luck
Not sure if this will help you or not, its just an example, But here is a link to an oil cooler adapter which bolts to my engine block LS3 type
LR Oil Cooler Adapter For Corvette C5 C6 C7 LS1 LS2 LS3 LS6 LS7 GM Camaro 843401102900 | eBay
I'm guessing your looking for similar thing, This one seals with a gasket.
LR Oil Cooler Adapter For Corvette C5 C6 C7 LS1 LS2 LS3 LS6 LS7 GM CK 99-07 BK 843401102900 | eBay
Maybe you can find an adaptor that uses a gasket if your not having any joy with O rings.
As for o-ring size, you should be able to work out the correct size from the grove depth and width,
you might need to check if you need metric or imperial
Parker O-Ring Selector / Calculator
Btw Ian, read your install with admiration, great work what a bloody shame a couple of £1 O rings are causing you this!!
Cheers, Lee
My sympathies with the oil leak - I had a similar issue with my Ford FE remote take off plate and the hoses, which on initial drive out sprayed oil onto my nice white headersfine on tickover and revved, but less so when under load. Perhaps I was lucky to avoid a fire. Took me ages to sort out the leaks.
Not sure if this is relevant, but the take-off casting on the side of my block wasn't flat. I used an old mirror, lots of water and wet'n'dry to ensure it was perfectly flat. I also had to have a couple of goes at making different paper gaskets of different thicknesses and checking everything was torqued in the right order and to correct specification. Still leaked a bit, and then virtually stopped.
