As you were changing carbs, could a vacuum line become cracked or broken and is leaking air?
If everything else fails, you could check your timing. Too much advance at idle will cause the idle to be high. How your vacuum advance is connected can cause issues at idle, but after that, everything stays the same.
Just speculation on my part in the event you get nowhere, but it really should be an adjustment on the carb as the others have mentioned.
