Results 1 to 3 of 3
    Aug 2003
    Rugby, Warwickshire, UK.
    91
    Rover V8 gear lever mod
    Has any one any ideas for easy modification of the standard rover gear lever which is far too long to be practical.
    The problem is it appears to be hardened steel so I can't even cut it.
    Anyone already solved this problem ?
    "WHO'S IDEA WAS IT TO BUY THIS" ?
    Jake
    Keith
    :-} Ignition upgraded and back on the road again
    Stoke on Trent.
    387
    RE: Rover V8 gear lever mod
    It's hard to cut :} so don't. The top half and the bottom half fit into a rubber cored squared off sleeve, reduce the lentgh of this and weld it up, the rlack of rubber cushioning doesn't affect the gear change. While you're doing this bend the whole thing forward so that the gear lever is canted forward, IMO it looks good and you can set it so that the gear knob falls nicely to hand.
    Kev
    Aug 2003
    91
    Cheers for the info Kev, I'll give it a try.
    Jake
    Keith
  1. Gear shift lever
    By JonnyT in forum General Tech Tips & Questions
    Last Post: 23-05-08, 11:07 AM
  2. Gear Lever
    By Bigblock in forum General Cobra Discussion
    Last Post: 18-04-07, 11:49 PM
  3. Gear Lever
    By Phil McCann in forum Pilgrim Sumo Technical Questions
    Last Post: 25-03-05, 09:47 AM
  4. TKO gear Lever
    By salmon in forum General Tech Tips & Questions
    Last Post: 01-10-04, 11:51 AM
  5. BW T5 gear lever
    By macca in forum General Tech Tips & Questions
    Last Post: 26-07-03, 12:23 PM
