Results 1 to 7 of 7
    Dec 2003
    chesterfield, derbyshire, united kingdom.
    RV8 ENGINE MOUNTS
    JUST RECEIVED MY ENGINE MOUNTS FROM PILGRIM,THE TRIANGLE PART THAT BOLTS TO THE BLOCK DOESNT LOOK VERY STRONG,(HOLES DRILLED CLOSE TO EDGE )HAS ANYONE EXPERIENCED ANY PROBS/IS THIS NORMAL?
    THANKS :f
    Feb 2002
    Swindon, Wiltshire, England.
    532
    RE: RV8 ENGINE MOUNTS
    It's normal and they're strong enough. Don't worry about it.
    Tony B
    http://homepage.ntlworld.com/tony.breski
    Sep 2003
    Wilrijk, Antwerpen, Belgium.
    196
    Compared to the Ford V6 stands I had before (I was planning on putting a V6 2.9L in there) the Rover V8 engine mounts looks really simple. I haven't seen where they fit on the Rover (I'm still waiting for my Rover V8 3.9L rebuild), but I guess they're suitable for what they will be used for.
    Michael
    Who said building a cobra is cheap ?
    Current status: fiddling with engine...
    http://www.modul8.com/cobra/
    Feb 2002
    532
    Here's some pics of where they are fitted. Where the engine is sat on the trolley, you can see where the brackets bolt in.
    http://homepage.ntlworld.com/tony.br...hortengine.jpg
    http://homepage.ntlworld.com/tony.br...artermotor.jpg
    Tony B
    Dec 2003
    OLDHAM, LANCS., UK.
    65
    You may need to file out the holes slightly as my bracket didn't line up with the engine holes.
    Also watch out for the starter motor as Tony's pic shows. I was unlucky in the fact I had a larger starter motor which meant the electrical connections rested on the engine mount, hence earthed !
    I agree, the bracket does look a bit flimsy. I've only found one example of a fail though, check out the link for a photo.
    http://www.cobraclub.com/crcforum/user_files/356.jpg
    I decided to fit it and worry about it as an when it does fail.
    Jon
    Feb 2002
    532
    Jon,
    If that _IS_ your plate with the crack in it, I'd replace it PDQ!
    Tony B
    Dec 2003
    OLDHAM, LANCS., UK.
    65
    Fortunately not !
    My car is still in two bits, shell at my house - chassis at dads.
    I spotted this pic whilst trying to figure out which holes to use, but I agree with the earlier thread - they do seem weak and the bolts are, I feel, too close to the edge of the plate.
    On mine I have about 5mm between the bolt hole and the edge. I've used a large washer on both sides to try and spread some of the load. I really don't fancy having to change one of these mounts at a later date.
    In hind sight, I wish I'd had them strengthened before fitting the engine in.
    JOn
  1. engine mounts
    By 427sc in forum General Cobra Discussion
    Last Post: 06-05-06, 01:43 PM
  2. Engine Mounts
    By PaulF in forum General Tech Tips & Questions
    Last Post: 05-01-05, 09:31 PM
  3. RV8 engine mounts
    By dave jenkins in forum Pilgrim Sumo Technical Questions
    Last Post: 01-05-03, 10:02 AM
  4. RV8 Engine Mounts For A Dax
    By BenBaron in forum General Tech Tips & Questions
    Last Post: 28-12-02, 04:25 PM
  5. Dax engine mounts
    By David in forum General Tech Tips & Questions
    Last Post: 22-08-01, 01:31 PM
