Results 1 to 4 of 4
    8,544
    ground clearance
    I seem to have very little ground clearance, how have you lot overcome this? :tu
    BIG TONE
    Dorset, UK.
    1,150
    RE: ground clearance
    Keep away from speed bumps & raised manhole covers{-}
    How low is low?
    If you're talking under the motor, I have about 100mm under the sump.
    If you have significantly less then some options would be to sit the motor higher, fit a different sump (may involve also changing oil pump pickup) or dry sump. Maybe your wheel/tyre size could increase a little.
    Experience enables you to recognize a mistake when you make it again.
    Nov 2002
    Westonzoyland, Somerset, England.
    237
    Tony,
    I have about a 100 mm as well, did not cause me a problem with speed bumps etc on the way to and from SVA.
    I think windin gup the Spax will give a bit more height.
    Dec 2002
    kent
    3,019
    I,ve only got 2" of clearance from the sump but have yet to fit the right wheels.after talking to Tim at raceways and explaining this i should have about 3"1/2 inches clearance and will then have to adjust suspension if its to low
    Gareth
    Gareth
    Seriously modified Sumo with a Ford 363. SOLD. Now building a Mercury Cyclone Spoiler.
  1. Ground clearance
    By eng622 in forum General Cobra Discussion
    Last Post: 21-03-07, 09:09 PM
  2. Ground clearance
    By fredo in forum Pilgrim Sumo Technical Questions
    Last Post: 30-09-06, 04:55 AM
  3. Ground Clearance
    By Frosty in forum Pilgrim Sumo Technical Questions
    Last Post: 17-09-03, 06:27 PM
  4. Ground clearance
    By 427sc in forum General Tech Tips & Questions
    Last Post: 23-01-03, 04:51 PM
  5. Ground Clearance
    By JohnW in forum General Tech Tips & Questions
    Last Post: 07-11-02, 08:22 PM
