Results 1 to 10 of 11
    Adrian Guest
    Help - Water in the Distributor !
    Anyone any idea why I've got water pouring out of the distributor when the engines running of my Rover V8?
    I've taken the water pump off to have a look but can't figure out why its coming out of a hole in the bottom of the dizzy??
    Adrian
    May 2003
    stevenage, herts, uk.
    1,095
    RE: Help - Water in the Distributor !
    Adrian
    I assume your serious.Coz this sound very.I cant imagine anyway water can get into the dizzy.If its a Mallory I could understand if oil was coming out of the hole.But I cant imagine any way water could and the engine still run.Sorry. -0
    Steve G
    GRAVETTI 427-Rover 281ci.
    Regards Steve G
    GE427(Rover 281)Not blue-well a bit.
    Stoke on Trent.
    387
    Wate coming out of the bottom of the dizzy!!!!! x( No way Jose. The dizzy runs in the front timing cover and is driven from the end of the camshaft. If there was water somehow getting from the water pump to the tiiming cover it would fill the engine. Are you sure water hasn't got into the dizzy somehow from the top and is being worked out when the dizzy is spinning? Let us know what it tiurns out to be. I'm intrigued.
    Kev
    Adrian Guest
    Guys,
    I'm afraid to have to admit its my fault.
    I've just realised that I've connected the vacuum pipe to the outlet at the front of my manifold (Twin SU's) which must be water and not vacuum.
    Think I'll go back to building computers.
    Adrian
    Stoke on Trent.
    387
    We've all made daft mistakes, me more than most. BTW check the vaccuum unit it sounds as though it's leaking.
    Kev
    Adrian Guest
    Kev,
    Have you put that 4.6 in yet?
    Adrian
    May 2003
    1,095
    Well another mystery solved.Dont give up engines are a lot more simple than computers.
    Steve G {-}
    GE427-Rover 281ci.
    Regards Steve G
    Adrian Guest
    Guys,
    Here's the offending pipe, any ideas what it should be connected to?
    Adrian
    http://www.cobraclub.com/crcforum/user_files/1047.jpg
    May 2003
    1,095
    Adrian
    It could be take off for the crankcase breather.Its not too clear in Mr. haynes but its the only pipe I can see in the manual that is close.But it wouldnt have water in it.
    Steve G
    GE427-Rover 281ci.
    Regards Steve G
    Stoke on Trent.
    387
    change of plan {-} Ian Richardson at Wildcat is at the moment modifying the block and crank and making new heads pistons etc., to take it out to 4.8 with a lot better breathing. Should be back for me to start the build late Feb or early March. ~~
    Luv these new icons
    Kev
  1. Unilite Distributor
    By cliffords in forum Engine Tech Tips & Questions
    Last Post: 16-05-07, 08:39 PM
  2. Advice needed to stop water gettiing into my MSD distributor
    By ramcobra123 in forum General Cobra Discussion
    Last Post: 13-05-07, 10:52 PM
  3. Distributor
    By harvey in forum Engine Tech Tips & Questions
    Last Post: 11-06-06, 08:09 PM
  4. RV8 Distributor
    By robinj66 in forum General Cobra Discussion
    Last Post: 04-03-06, 08:57 PM
  5. SBC Distributor
    By garyholden in forum General Tech Tips & Questions
    Last Post: 14-07-05, 07:44 PM
