    Aug 2002
    st.neots, cambs, uk.
    158
    Prop 4 a 5 speed RV8 box
    Hi Guys,
    I'm in the process of removing my "tired" 4 speed overdriven rover box to replace it with a 5 speed unit I've picked up through the CRC.
    I need a prop specialist in the North Beds/South Cambs area, any ideas??
    I intend to obtain a Range Rover prop and have it chopped about & the Jag flange welded onto the back end. The reason being is that when the 5 speed box goes into the car I will end up with a flange at either end. Using the R/Rover prop will allow me to retain the central spline for the play necessary.
    If anyone has a better idea/experience, please post a reply!!!!!
    Thanks in advance,
    Ian.
    Sold, Now looking for a BIG engine!
    May 2003
    stevenage, herts, uk.
    1,095
    RE: Prop 4 a 5 speed RV8 box
    Ian
    Lad at work had a prop cut and balanced little while back,will get number off him on monday and post it.Think it was biggleswade,Sandy way.
    Steve G
    GE427-Rover 281ci.
    Regards Steve G
    GE427(Rover 281)Not blue-well a bit.
    russell_ram Guest
    The i/p flange on a Jag diff are exactly the same as the o/p flange on a Rover box (and also any Range Rover/Discovery/Defender) So you just need a Land Rover prop thats long enough and get it shortened. Use a rear prop by preference because they are much bigger diameter (although diameter isn't strictly a issue with the short props we use).
    Russ
    Aug 2002
    158
    Thanks for the info chaps, it's all beginning to make sense.
    Ta !!
    IAN
    Oct 2003
    Hoddesdon, Hertfordshre, U.K..
    182
    I have a Dax supplied shortened prop for 5 speed rover to Jag diff-going spare. Came off my supertube chassis.(now run T5)
    Might be worth a call to Dax to ensure all chassis use same prop length (think they do).
    This unit has sliding adjustment built in.
    If its any good to you let me know.
    I used a place in luton for my new unit Reco-Prop (UK) Ltd. 01582 412110. They were very good.
    Baldric
    Baldric
  1. Prop Shaft
    By digger782 in forum General Cobra Discussion
    Last Post: 30-11-07, 05:01 PM
  2. Prop Shaft
    By BenBaron in forum General Tech Tips & Questions
    Last Post: 15-06-06, 04:02 PM
  3. bonnet prop
    By coomers in forum Pilgrim Sumo Technical Questions
    Last Post: 26-07-05, 06:57 PM
  4. Rad and Prop
    By rich in forum AK Technical Questions
    Last Post: 16-10-04, 01:00 PM
  5. Speed Sunday: The Goodwood Festival of Speed
    By Louise in forum General Cobra Discussion
    Last Post: 26-06-04, 03:11 PM
