All Rover cylinder heads are OK for unleaded.
There is no difference between a Vitesse cylinder head and a standard SD1 head . All heads between 76 and 95 are the sameas far as we are concerned. Before 76 valves were smaller (inlet 38 vs 40mm, ex 34 vs 33mm dia). Post 95 (10 bolt heads) are different - port bigger inside, fire face moved upwards for composite gasket and, of course, only 10 vs 14 cyl head bolts (these are the best std heads).
Russ
