Results 1 to 7 of 7
    Mar 2003
    202
    RV8 Spigot bearing
    Hi folks,
    I have a RV8 and the engine number traces it back to a SD1 with manual box,
    I have completed a re-build and it is ready to go. The gearbox I have is a late 'd' type LT77 acquired seperate to the engine.
    On measuring the diameter of the primary input shaft of the box this measures 10mm, when measuring the innner diameter of the spigot bearing this measure 13mm. Does anyone know if this is ok or could it be that I have a spigot bearing for an auto in the engine, even though the engine was originally fitted to a 5 speed box.
    Also just to complete my knowledge, could someone tell me what the spigot bearing is there for
    Dave
    ' and it was going oh so well '
    Aug 2002
    weymouth, dorset.
    80
    RE: RV8 Spigot bearing
    Perky,
    This has been covered before. Try a search on "spigot bearing" and you should find the info.
    martin
    4.7 RV8, Power Steering. was Supercharged, but thats now sold. Megasquirt-n-Spark Extra, running Fuel & Coil Packs in Wasted Spark.
    russell_ram Guest
    Dave,
    see attached pics.
    Manual and Auto spigot bearings are very 'obviously' different.
    Spigot bear supports the input shaft and holds it inline with the crankshaft. It also reduces wear on the intermediate bearing between the gearbox input and output shafts, which in an LT77 is a small taper roller bearing not designed to run 'out of alignment'.You must use a spigot bearing of the correct diameter in the crank.
    If your input shaft really is 10mm dia, then it could have been ground because of previous wear (unlikely - not being rude but how did you measue it?). If it is, you'll have to get a bearing machined up from phosphor bronze to the correct dia for your shaft.
    Russ
    Mar 2003
    202
    thanks russ
    looking at the pictures I definately have a manual spigot bearing, so now I need to measure the input shaft acurately,
    thanks fo rthe advise
    Dave
    Stoke on Trent.
    387
    Just measured bearing and shaft on my manual SD1 engine, both are coming out at 12.7mm according to my verynear.
    Kev
    Mar 2003
    202
    Thanks all for the replies.
    Checking the input shaft nose this measures to spec but measuring the part of the shaft that mates with the bearing this is nearer 10mm so off to the gearbox doctor I go - will report back soon,
    bloody anoying given I paid a fellow fake snake charmer on this forum 300 for the 'box, talk about buyer beware !!!!!!!!
    (Ian you know who you are !!!!)
    Dave
    'and it was going oh so well'
    Mar 2003
    202
    Now back from seeing Dr Gearbox and I now have a luverly LT77, the chap sorted the Input shaft problem and whilst he was at it replaced a worn selector fork, seals and a worn bearing.
    If you are in yorkshire then this chap is in Leeds, contact me if you need detials of a gearbox doctor
    Dave
  1. Replacing Spigot Bearing
    By martin_t in forum General Tech Tips & Questions
    Last Post: 01-07-07, 11:08 PM
  2. Needle bearing
    By davep in forum General Cobra Discussion
    Last Post: 05-06-05, 12:09 AM
  3. Spigot Bearing Clearance
    By Barry Davolls in forum Engine Tech Tips & Questions
    Last Post: 06-05-04, 06:36 PM
  4. Crankshaft Spigot Bush
    By Phil McCann in forum Engine Tech Tips & Questions
    Last Post: 26-03-04, 11:33 AM
  5. Water pump/fan mounting spigot
    By beanpole in forum Engine Tech Tips & Questions
    Last Post: 28-04-03, 08:55 AM
