Results 1 to 8 of 8
Thread: Broken Carb
    Dec 2003
    OLDHAM, LANCS., UK.
    65
    Broken Carb
    I ( was ) running an RV8 with twin Stomberg CD175 carbs.
    Wanting the engine to look 'nice' I tried to straigten the carb's choke fuel pipe linking each carb - one snapped off at the base ( as per photo )
    Any ideas if this is fixable ?
    If not, does anyone know where I can pick up a couple of decent SU's, I don't really want the extra expense of a new inlet manifold.
    Alternatively, if I decide to go mad on the credit card ( again ) which is best, the weber or the holly carbs, and where's the cheapest place to buy ?
    Jon
    http://www.cobraclub.com/crcforum/user_files/4016.jpg
    http://www.cobraclub.com/crcforum/user_files/4018.jpg
    Stoke on Trent.
    387
    RE: Broken Carb
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...category=31348
    currently at £0.99 with manifolds!
    Kev :tu
    Dec 2003
    OLDHAM, LANCS., UK.
    65
    RE: Broken Carb
    Thanks kev, I know SU's can be OK. Anyone know if it's worth while getting new stromburgs, or am i best just throwing in the bin.
    Jon
    Stoke on Trent.
    387
    RE: Broken Carb
    ??? x( they are strombergs, I thought that's what you wanted.
    Kev
    Dec 2003
    OLDHAM, LANCS., UK.
    65
    RE: Broken Carb
    Purely looking for a cheap job at the moment, and never thought of e-bay.
    I was more thinking if this isn't repairable, are SU's any better than strombergs. If I'm replacing the whole lot I may as well buy SU's - IF they are any better.
    Jon
    Stoke on Trent.
    387
    RE: Broken Carb
    Russ is the man to answer that type of question. I would have thought that it would be better to make do at the moment, save your pennies and then get something a lot better, e.g either a Webber500 or even better go to full engine management.
    Thing to bear in mind is to spend your pennies wisely, you can throw an awfull lot of money at an RV8 and not achieve the desired effect, the heads don't flow very well so it's pointless putting on anything much bigger than a weber500 for road use and spending oodles of cash on head work is probably not cost effective if you want lots of gee gees. If you're happy with the performance stick with it as is, if you're not happy with the performance then check out the options very carefully, there is an awfull load of bullsh*t spoken about this engine.
    regards
    Kev :tu
    Dec 2003
    OLDHAM, LANCS., UK.
    65
    RE: Broken Carb
    Thanks kev,
    I'll stick to the stromberg or SU's for now, I'm sure these'll be fast enough until I get used to a rear wheeler again.
    Cheers.
    Jon
    Aug 2002
    Hayes, middlesex, england.
    1,065
    RE: Broken Carb
    SU's are good for about 210 bhp maybe a bit more, If you want much more than that out of your 3.5 its going to cost lodsa dosh
    jeff
    Jeff
    Not all chemicals are bad. Without chemicals such as hydrogen and oxygen, for example, there would be no way to make water, a vital ingredient in beer
  1. I've Broken the Law!
    By Simon R in forum General Cobra Discussion
    Last Post: 18-10-07, 07:48 PM
  2. Thats broken it!! HELP!
    By MrFawlty in forum Pilgrim Sumo Technical Questions
    Last Post: 25-05-06, 01:30 PM
  3. Thats broken it!!! HELP
    By MrFawlty in forum General Tech Tips & Questions
    Last Post: 24-05-06, 11:28 PM
  4. Topsites broken?
    By kenf in forum Feedback, Membership and Help
    Last Post: 13-10-04, 05:41 PM
  5. Broken it already
    By andybrown in forum General Tech Tips & Questions
    Last Post: 13-09-03, 12:07 AM
