Results 1 to 10 of 11
    Shepshed, Leicester, UK.
    495
    Steel Braded Hose
    Anyone know a good place to get some steel braded hose from?
    I think I need to replace all my coolent hose and I think it wold look better with
    some steel braded stuff.
    Metaline Ford 390FE .. goes like a \'bullitt\'
    Nov 2004
    East Sussex
    3,283
    Re: Steel Braded Hose
    Paul, mine came from Merlin Motorsport Mailorder based at Castle Coombe Racecircuit, tel 01249 782101, another that springs to mind is Demon Tweaks. Alternatively you can use the new (ish) polymer hoses for the coolant which look and work pretty good too.
    Andy S (Maggot)
    SRV8 + CHEVY
    Isnt it a beautiful day - now watch some bastard louse it up !
    495
    Thanks,
    I couldn't see any on Merlin Motorsport site when I first looked.
    Jul 2004
    Davenham, Cheshire
    248
    Personally I wouldn't pay UK prices for stainless hose and fittings until you check out prices from US companies like Summit Racing or jegs.
    Chris
    10,009
    Try speedflow or Think Automotive (thinkauto.co.uk)
    You can buy hose braiding and annodised clamps etc. from both.
    It aint cheap but looks the boll**ks.
    In build- Hawk 289 Sebring
    Nov 2004
    Worcester Park
    I've always found Speedflow very helpful particulalry if you are unsure of what you need in terms of fittings & sizes (can be very confusing)
    Colin
    GDJag, EDA 383 SBC
    Colin
    GD Jag, EDA 383ci Chevy
    Jan 2001
    On the naughty step
    13,798
    Paul - what you need for decorating coolant lines is stainless "overbraid" - i.e. an overlay of stainless weaved tube that slips over your rubber coolant hoses and is kept in place by special hose clip thingies.
    BUT - what you need for high pressure lines like oil cooler lines is completely different - that is aeroquip-type hose, where the stainless outer braid is part and parcel of the hose and it's strength.
    As someone above mentioned, thinkauto is the dog's parts for oil cooler lines and fittings. Cheapest source you can find (UK or USA) for the coolant hose overbraid is OK.
    Hope to be at the Castle this Sunday if you want further info. BTW, sorry to hear about your engine problems.
    495
    Hi Wilf,
    Engine rebuild is going well, as is the gear box rebuild. The oil and fuel lines are already braded steel. I need to replace the water lines as we found a lot of them were perished (or at least on their way) when we took out the engine.
    It doesn't look to costly too replace (well compared to the engine re build with new pistons, bearings, cam, rockers, springs, valves, oil pump and a few other minor things!)
    495
    I might be being really dense! but the sizes 6, 8 ,10 etc what are they?
    I assume inside dia in mm.
    May 2003
    Letchworth, Herts, UK
    146
    Quote Originally Posted by MetaJacko
    Paul - actually no, but this should help http://www.earls.co.uk/car/7_plumbin...ing_basics.pdf - it helped me when plumbing up my engine. If you want to have identical hose throughout like I did, they even do water hose and fittings that's made the same way as the higher pressure stuff wilf mentions - they even do the hose big enough for the top an bottom rad hoses but be aware - it's about 100 a metre .
    Mark
  1. Beg, Borrow, Buy, Steel.....
    By BenBaron in forum General Cobra Discussion
    Last Post: 07-11-06, 11:44 AM
  2. real steel
    By easthamr in forum General Cobra Discussion
    Last Post: 26-07-06, 09:46 AM
  3. Real Steel
    By cliffords in forum General Tech Tips & Questions
    Last Post: 24-07-06, 09:51 PM
  4. Vacuum Hose / Fuel Hose
    By bc_suv in forum General Tech Tips & Questions
    Last Post: 21-05-06, 11:28 AM
  5. WARNING Russell Pro Flex Steel Braided Hose
    By Paul Gayter in forum General Cobra Discussion
    Last Post: 25-04-06, 07:08 PM
