| 70 litres according to the spec = 15.35 gallons. Could lead your calcs to be more like 15.6 mpg, which isn't the best unless you were booting it a bit :O
__________________ Share your Cobra knowledge here on the Sumo Wiki ...and don't forget, building cars is meant to be fun!! |
| To be honest mate, you may as well come round to my gaff, all this stuff can be sorted out easy enough. I may even have the needles, I'd have to check, I may have used them to make my home-brewed set that my car is running at the mo. Have a look at the webber post that's running at the mo, I can't remember who I've told what to! There is a load of gumph in that post about these carbs. oh by the way, I wouldn't bother going to Pilgrim, its a waste of fuel! If you want to come round PM me your number so that we can sort something out. Pete - thanks for that, will take you up on the offer. To be honest, Pilgrim have been pretty good sorting out the mechanical/bodywork stuff for me for free (bought the car off them) but they're not set up for the tuning part. also saw the Weber post too, very useful. PM on its way to you. cheers Dave
__________________ Dave Smith Sumo III RV8 3.9 www.solutrean.co.uk www.linkedin.com/in/d8smt |
| Just a quick update for anyone that is interested! Dave came round yesterday so we had a look at his setup. The carb was setup as "out of the box" so we stuck in the 67x55 needles and set the float heights up. The mixture screws were setup by listening to how the engine responded, they ended up being slightly odd, one side was 1.5 turns, the other being 2.25. I think that the "offy" dual port manifold is made so that both primary chokes feed all 8 cylinders so each mixture screw effects all of the engine, not half of it. (Can anyone confirm this?) If this is the case then the the difference must be down to tolerances in the carb. The timing was quite stable at 10 degees static 30 total all in at 2800RPM. (I was very supprised as its running points The vac was kicking in hard just off tickover and putting the timing up to around 45 degrees. This I think was the main problem with the jerkyness. Anyway, its now running 14 static, 34 total and NO VAC. (port in the carb bunged up) The results.....well Dave is quite happy! Other things that need doing are sorting out the crankcase breather system, at the mo the carb is not connected , the big hole in the carb is bunged up. I was told by Real Steel that the carb is calibrated to be "expecting" air from this port so I guess the current setup is going to be a bit rich. An insulation plate is also required along with a bit of work on the throttle spring. Oh, the fuel pump delivers 2 pints per minute which I think is enough, Dave will have to work it out! (We don't know what the PSI was, but my finger over the end of the pipe test would indicate that its not mega high!) The fans are more or less on all the time which is giving the alternator a hard time! Dave I'll get the part numbers over to you of the bits and bobs that you need. Pete
| Think your right Pete Both the primaries feed all 8 cylinders and when the secondaries open all 8 are fed again. Rover V8 - JWR / Offenhauser Intake Manifold 4BBL - New on eBay, also Engine Tuning Parts, Performance Tuning Parts, Car Tuning Styling, Cars, Parts Vehicles (end time 24-Oct-08 21:53:24 BST) Craig.
__________________ Dax Tojeiro, + 355 Chevy + Tremec box = no more money! TWM Fuel injection now up and running! Sounds and runs superb. Polishes to date = 27 |
| Yep, big thanks to Pete, all the jerkiness & hesitation has now disappeared and the car is running much, much smoother across all the rev bands and particularly when giving it some power. The thing still has difficulty starting hot, but Pete's given me a couple of pointers on this, not least the spacer between the manifold (Offenhauser) & carbs plus I also found an interesting article last night about problems with hot starting on Mallory distributors which could also be a contributory factor.... MGB - Rover V8 Engine Problem & so once the electronic parts for the ignition arrive this week I'll upgrade those & see if it makes a difference to the hot starting. Again, big thanks to Pete for not only sorting it out but teaching me how it all fits together as well. Cheers Dave
| Ammeter reading | RAM427Cobra | General Tech Tips & Questions | 8 | 10-05-08 11:59 AM |
| SD1 top hose near Reading | alastaid | General Cobra Discussion | 1 | 30-04-05 02:07 PM |
| Engine Tuning in the South East - recommendations | alastaid | Engine Tech Tips & Questions | 1 | 24-03-05 06:47 PM |
| oil pressure reading in bar/psi | keane | General Tech Tips & Questions | 5 | 18-03-05 08:33 PM |
| A Trimmer near Reading ? | alastaid | General Cobra Discussion | 3 | 19-06-02 09:53 PM |
