| Re: Pedal height? Kevin, I dont think its a fail but try bending the accelerator pedal so its more in line with the brake for aesthetic reasons and it wont look half as bad. Cheers, Tony
| Re: Pedal height? Kevin, Have you considered packing out the clutch master cylinder from the bulkhead? Due to the pedal and operating rod geometry, a small thickness packer at the master cylinder can make quite a large difference at the pedal rubber & it saves stripping down the pedal box assembly. I successfully did this on a road car years ago.
| Re: Pedal height? Bending the pedal to match would not be the easiest thing, but packing out the cylinder would not take too much effort. I will see what i can do over the next few days. Cheers for the advice.
| Re: Pedal height? Hi, Packing out the clutch seems a good idea, but isn't the clevis ajustable ? You may also have to watch the travel on the clutch pedal as you may be putting all your force against the master cylinder when it reaches the end of it's travel, which may either bend the rod or damage the cylinder, if you push down to hard. I do not believe it is an SVA failure. Mark |
| Re: Pedal height? hi mark i have already wound the clevis as far down as it will go. i may have to remove locking nut from the shaft and also 'move' the hole in the clevis pin that bolts to the pedal. who said life was easy cheers for now
| Re: Pedal height? Quote:
Viper Easy Mutually exclusive as i said before :thumb:
| Re: Pedal height? I have drilled a hole closer to the pedal in the clevis pin. Both brake and clutch are equal now. Jobs a goodun as they say. Thanks to everyone for the help Cheers
| Re: Pedal height? Kev Just out of interest how high are your pedals from the floor? Cheers Dean.
| Re: Pedal height? I will check tonight Dean. All i can say at this moment in time is that with the brake pedal fully depressed (bit like you lol), then it is prob approx 1 inch from the bulkhead. Pedals are probably just a bit less than a size 9 shoe distance from the floor itself (with foot flat on pedal, normal car type positon). We have the marina pedal box, with significantly cut down pedal length. Cheers
| Pedal Box | lomondbob | DAX Technical Questions | 7 | 18-05-07 07:55 PM |
| Pedal length/height off floor | maverick | General Cobra Discussion | 8 | 08-06-06 11:38 AM |
| Dax pedal box | demus | DAX Technical Questions | 0 | 17-07-05 10:29 AM |
| Which Pedal Box | BAZ | General Tech Tips & Questions | 3 | 08-05-03 02:53 PM |
| PEDAL BOX | Shelby | General Cobra Discussion | 3 | 26-11-01 10:52 AM |
