| Re: Some dimensions please?? Hi. I may not be well enough on to be of use to you (not finished by a long shot) but got some measurements anyway... Approximately: Dimensions required:- Wheel diameters: halibrand with kuhmo 225/45ZR17 605mm : halibrand with kuhmo 245/45ZR17 640mm Distance from ground to Hub centre. half diameter of wheel Distance from hub centre to highest point of wheel arch lip (internal) Problem with this one is ride height not set (think I need to cut springs according to the "manual"!); front 715, with 108 from top of tyre to arch rear 770, with 130 from top of tyre to arch My guess is gaps are supposed to be around 30 - 50mm? distance from ground to lower air scoop on front. Ground to top of bottom edge of top air scoop opening: 345 Good luck with it! Declan
__________________ Declan RV8, Sierra based Viper. I'm sure if I give it enough love it will, someday, love me back!? |
| Re: Some dimensions please?? Declan cheers mate. I know what you mean about the set up but needed ball park figures to see if i am heading in the right direction. The main bit was the wheels, as i am still on the push around set.. Thanks Dean. PS could any one on the road get the tape out please?
| Re: Some dimensions please?? Richard Poulton had a fully finished one, i will try to dig out his email / username on here. Failing that, there was the guy with the vipersite website (on freeserve), i will also dig his particulars and PM you when i have 2 mins. Sailing on now then Dean eh? Best wishes
| Re: Some dimensions please?? Kev You're right Forgot about Dave. Getting there now. Should be time to take the body off again soon. Possibly this weekend even. you never know??? Cheers Dean
| Re: Some dimensions please?? Quote:
__________________ Robin AK427 sporadically in a state of build. |
| Re: Some dimensions please?? Ours will have max 3 inches clearance between bottom of fibreglass body (oil cooler air scoop) and floor. How is yours looking Dean?
| Dax Dimensions | velocity boy | DAX Technical Questions | 0 | 12-02-06 01:48 PM |
| Dax Dimensions. | martin_t | General Tech Tips & Questions | 4 | 11-02-06 03:11 PM |
| What are the Dimensions? | mark b | General Cobra Discussion | 2 | 15-09-04 06:59 PM |
| AK Dimensions | martyn | General Cobra Discussion | 5 | 01-02-04 04:33 PM |
| Dimensions | Andy302 | General Cobra Discussion | 1 | 22-11-03 07:56 PM |
