Old 11-07-06, 03:20 PM
kevchard's Avatar
Soft top fitted to Viper?
Has anyone got a soft top fitted to a viper (preferably cortina based Cobretti, DMS etc).
I am plannig the wind screen position but don't know what angle to put the windscreen at.
I was hoping that someone has bought a soft top kit recently, and could measure the angle of the side window (which i could use as a template to set the windscreen angle with).
Kevin
Kevin & Helen
DMS Venom Viper
Granada Cosworth 2.9V6 BOA
SVA passed Aug 07
Old 11-07-06, 03:28 PM
Iain's Avatar
Herd member
Re: Soft top fitted to Viper?
Sorry Kev I can't help you. My Viper is Jag based and a Classic Replicas too. I will be fitting one at some point but not for a while yet....
Hope you get sorted... :thumb:
Iain
http://www.fake-snake.co.uk/
Classic Replicas Viper
SVA'd Nov 2007
Old 11-07-06, 03:35 PM
kevchard's Avatar
Is there any actual difference between the body of a Jag or corty based Viper? Is the jag longer/wider?
I am not buying a roof or installing windscreen until after SVA. But want to be able to plan it all in advance.
I am probably going for Europa roof, unless someone has a better / cheaper choice.
Kevin & Helen
DMS Venom Viper
SVA passed Aug 07
Old 11-07-06, 03:57 PM
digger782's Avatar
Hi I have a Brightwheel viper and fitted a Europa roof and sides.
The body had studs fitted from another hood long gone so asked Europa to supply without studs fitted and 2 inches longer (no extra cost).
I will find the distance from centre of screen to front edge of body hope this helps:thumb:
Whats money for-Spending on your car:thumb:
Old 11-07-06, 04:44 PM
kevchard's Avatar
Thanks Digger and Iain
Don't supose you could draw a sketch of your side window, so as i can make a cardboard template.
Kevin & Helen
DMS Venom Viper
SVA passed Aug 07
Old 19-07-06, 12:36 PM
I seem to remember that the original manual (if you can call it that) that came with my Viper chassis (Jag type) gave a distance from the top of the screen to the edge of the bodywork behind the seats. 87cms rings a bell but I'll have to check at the weekend, if you think that would help?
David
David
:drive:
Old 19-07-06, 06:04 PM
kevchard's Avatar
Thanks David
Trouble is with ours i would need all the dimensions to mount the screen in roughly the correct place. The last bloke just 'plonked' the screen on to make it look more complete.
Any and all dimensions you have would be appreciated.
Kevin
Kevin & Helen
DMS Venom Viper
SVA passed Aug 07
Old 19-07-06, 08:08 PM
Club Sec/Rep Liason
Kev. All the "usual" supplied sidescreen frames come as "Cut to Fit" Likewise the Hoods come oversized at the front and you glue them to the hood bows to the correct tension. So just fit your screen in the best fitting postion/angle, and everything else can be adjusted to fit :thumb:
AK 427 351C T5wc
Old 19-07-06, 08:34 PM
kevchard's Avatar
Thanks Chris
Just when i thought i had formulated a plan as to fitting the screen. So do you mean you have to cut the side perspex windows to the correct angle for the 'A Pillar'?
In that case, what is the typical angle between the screen and the scuttle?
Also how far back is the bottom of the screen from the innermost past of the scuttle (above the dashboard)?
Any dims welcomed.
Thanks again
Kevin
Kevin & Helen
DMS Venom Viper
SVA passed Aug 07
Old 19-07-06, 08:52 PM
Club Sec/Rep Liason
Hi Kev. Yep thats about it :thumb: The sidescreen frames and perspex are cut to what ever angle you end up with. It all depends on which screen rake you like best/which angle suits your particular body/screen. I can't give you any dims as all kits are different
AK 427 351C T5wc
Windscreen fitted Daxman General Cobra Discussion 2 31-07-07 08:33 PM
Cobretti Viper vs Classic Replicas Viper CeeJay General Cobra Discussion 86 19-07-06 07:34 PM
L539's, anyone fitted these? madjohnny General Tech Tips & Questions 3 02-09-04 07:25 AM
Anyone fitted one of these on a Cobra? Robin427 General Cobra Discussion 5 03-11-03 03:46 PM
Has anyone fitted NOS to the Cobra? breskit General Cobra Discussion 11 25-10-03 03:53 PM
