| Re: Spring poundage? Cheers Looks like some trial and error when i get to that stage then..
| Re: Spring poundage? Quote:
Looks good in the garage now:rotfl: :rotfl: might be different in the light I'd challenge you to a race to completion but I've seen yours...(eh, on the previous page.) Looks really sweet!!. Reckon I could make next year too seeing as there's nothing left to replace...except the chassis and the bodyshell...did I just say that May the Force be with us Dec
__________________ Declan RV8, Sierra based Viper. I'm sure if I give it enough love it will, someday, love me back!? |
| Re: Spring poundage? Hi everyone, I'm having a whale of a time with my MkIII Sumo, Ford based with Chevy 5.7 apart from the persistent grounding of the sump! Springs and shocks under review - any advice as to the best setup of shocks/springs/ride height gratefully received. I have been advised that I need 600lbs front, 700lbs rear - what do you think, which shocks are best suited and where would you go to buy the springs/shocks? My car is the one with the Cobratops hardtop - picture under gallery, General pics. Regards Rudolph Hucker
__________________ It's official! British weather has been declared Muslim. It's partly Sunni but mostly Shi'ite. |
| Re: Spring poundage? Hi Dean Thanks for info :thumb: Trouble is with coil overs, you will need to strengthen the lower wishbone, as instead of the weight of the spring 'pushing' the top of wishbone down (acting on a large strong area), it 'pulls' down (on a thin plate from under the wishbone). That is what's putting me off (and the cost for a min). Thanks for the offer Dean of your shocks. We will be down in Nov for Exeter car show (hopefully). Cheers Kevin
However I am going to fabricate a bracket that will transfer the load to the inside of the lower wishbone. this should provide the strength and adaptability. Other than that it will be a complete remodel of the front suspension for something a little more adjustable................ I should be around in Nov. May try to get to the show but very busy at work at the mo. 9 week shutdown again......You are welcome to the sprngs as they are cluttering up the garage at present. Cheers
| Re: Spring poundage? With regard to suspension and the Viper, if your car is using Avo dampers/springs and you are having trouble then it might be worth contacting Avo. I spoke with them today via several e-Mails, one of which I let slip that the suspension was bought with the kit direct from Ken "Super Knob" Cook. At that point the guy completely understood my problems. I have now got a new suspension (2off dampers and springs) which should hopefully sort me out! Just so that you guys know, I am not using the standard Jag setup with 4 dampers (2 per side) but instead I am fitting just one. Along with that, I am bracing the wishbone to strengthen it up and then I am removing the Jag Radius Arm completely. I saw that the "Jaguar Car Club" racer boys do this to their cars for racing so it should do me a treat! :thumb: Anyone having problems with their Viper suspension (and it is an Avo setup) then it might be worth a call. Their web site is http://www.avouk.com/ Cheers... |
| Re: Spring poundage? I have fitted 235 Lb springs to one side, but car is still too low and too soggy. I have now ordered 270Lb Heavy Duty springs from Rally Design. Hope these are better.What do you think is the stance on 'spring assistors' for SVA? Cheers
| Re: Spring poundage? We have installed 270Lb springs. The car hardly moves at all now when we lower it from the axle stands. The car is legally high enough for SVA and suspension is soft enough. We will be looking into coil overs after SVA for more flexibility tho. Not sure what the difference is in weight between the RV8 and our V6. Cheers
| Spring Cleaning | robert | General Cobra Discussion | 0 | 20-06-06 07:37 PM |
| Spring lifters | nbracken | General Tech Tips & Questions | 0 | 23-04-06 12:24 PM |
| What poundage springs? | Iain | General Cobra Discussion | 17 | 30-03-06 08:52 PM |
| Spring Rates | gwak76 | Pilgrim Sumo Technical Questions | 12 | 14-01-05 10:05 PM |
| spring lbs plz | MARTIN123 | General Tech Tips & Questions | 2 | 05-09-03 09:56 AM |
