| Vented discs on corty front end Hi all. Just need some confirmation here. I have the standard cortina front disc (solid) set up with princess 4 pots fitted. I want to fit vented discs to the front due to using the Rv8 (soon to be upped a bit from standard!). I have the required spacing kit for the calipers (removed it to fit the standard discs) but would like to know which discs to go for.. I believe from other posts that Capri ones fit but Do the following fit without further mods?? http://cgi.ebay.co.uk/FORD-CAPRI-2-8...QQcmdZViewItem Thanks in advance:thumb:
| Re: Vented discs on corty front end Just wondering how you have connected the brake pipes. The AP calipers originally had two flexi pipes into them. I tried this setup but found that the standard Cortina/Capri master cylinder then had too much travel. I eventually went back to the original design of one flexi pipe which then "splits" at the caliper - works fine and brakes are very smooth
| Re: Vented discs on corty front end Hi Robin Thanks for the reply. All I need now is some more money to get the discs.. will check the spacers when I am next on the car. calipers are connected as I got them like the piccie I found one of your earlier posts about the brakes locking up. I take it the change you made sorted that out then?? Looks like I may have to repipe the front end slightly?? I must add that I haven't actually filled the brake system yet as i am waiting to put the engine back in first.....Just in case!!!
| Re: Vented discs on corty front end Hi Dean The problem appears to have been solved by replacing the master cylinder. Changing the seals in the old one didn't cure it - maybe the bore was worn more than I thought. Just looking at your pictures - you have connected a pipe to one of the bleed nipples - can't see any reason why it shouldn't work but you should be aware that these calipers can be a real PIA to bleed sometimes. let us know if your system is succesful once you get the fluid in. What have you fitted re shocks/springs. I appreciate yours is a different kit to mine but I'm toying with the idea of trying to fit coilovers to the Cortina front end. Is that what you've done?
| Re: Vented discs on corty front end Hi Thought they were plumbed a bit silly but I am at the stage where everything can still be changed. Not decided on the front suspension yet. All I have is 2 off 3" long pieces of scaffold tube holding the front level. May be a bit bumpy and not very forgiving at the mo. The standard springs left the front about 6" higher than it should be which didn't look quite right!!!! Its a toss up between coil overs or something completely different. Just need to see what space I have left when the engine is in place. Will let you know when I discount it all and just chop 3" out of the springs.......
| Free Hawk front discs | dingocooke | Hawk Technical Questions | 4 | 03-09-07 04:12 PM |
| PCV Valve and vented filler cap | dingocooke | General Cobra Discussion | 4 | 22-06-07 04:29 PM |
| Hawk vented disc identity | dingocooke | Hawk Technical Questions | 20 | 31-01-07 07:48 AM |
| sumo front hub/discs | MrFawlty | General Tech Tips & Questions | 8 | 09-03-05 07:36 PM |
| Granada Front Discs | Phil McCann | General Cobra Discussion | 1 | 21-01-04 04:20 PM |
