| Re: Mating exhaust and down pipes Quote:
CeeJay.
__________________ Got engaged on xmas day so I have 15 months to get the cobra finished so I can drive it to my own wedding - I'd best get the finger out... |
| Can't help on the particular Viper related issues but on the subject of exhaust flexing, I have range rover engine mounts on my RV8 and no flexible portions in the exhaust (mine has an underbody system); minimal engine rock and careful mounting of the exhaust has served my car well for 18 years. Cheers
__________________ David Large Bald Surfer with a BRA 289 |
| You don't need a flexi joint if the engine is mounted with a steady bar and the exhaust is designed and mounted accordingly. Fitment of an engine anti-torque bar from head to chassis is a fairly easy process. This allows much closer clearances as far as exhaust mounting goes, particularly with underfloor systems. It can also help with cooling hoses and the like. Some Rover engines wobble about like a jelly, Chevy's are not so bad and Ford's seem fairly solid as standard. Most side pipes come with two mounts. You only need the rear mount as long as the front joints are designed to stay tight. ie. not slip joints. Flange plate fitment is suitable or tight slips and springs. Avoid mild steel slips as I have seen corrosion in the joints lead to a very loose fit after time. Andy
__________________ A S motorsport Ltd. 01379 688356 mob; 07909531816 web; asmotorsport.co.uk email \"andrewsoar@yahoo.com\" |
| Sorry Iain I just couldn't resist it! As for Dinosaurs comments, I have never heard of a steady bar before, but I'm going to be looking into this idea in the next day or two as removing the flexi pipe from the set-up would be a great help. Did you buy the steady bar or is this something you made yourself? Regards CeeJay.
| Quote:
I'll put the precision shims away just in case you need them! Cheers... |
| Quote:
CeeJay...
| The steady bar in the picture was a Jaguar anti-roll bar post, complete with rubber bushes. Rover P6's used a similar (but much slimmer) rod mounted in a similar manner. Rubber bush one end and a rod end at the other is another way. Andy
| Quote:
CeeJay.
| Exhaust Pipes / Fans and Quick Lifts | danny b | General Cobra Discussion | 46 | 08-07-08 06:05 PM |
| Indian Mating Season!!!! | the rock doc | The Cockpit | 0 | 04-07-07 07:00 AM |
| exhaust pipes | tonym | General Tech Tips & Questions | 13 | 12-10-06 11:27 PM |
| Flexi exhaust with side pipes | darren | Pilgrim Sumo Technical Questions | 9 | 12-09-06 08:39 AM |
| Mating Engine and Stand | Olddogjon | Engine Tech Tips & Questions | 4 | 02-10-03 10:46 PM |
