Old 20-08-07, 08:19 PM
CeeJay's Avatar
Spring Heights
Hi All
I'm getting to the point in the build where I need to consider spring heights. Currently my car body sits rougthly 5 inches to high - I know that several of you have sorted this out - can anyone let me know what spring heights/poundage I should be using on my for cortina/sierra setup with a rv8 anchor?
CeeJay.
Got engaged on xmas day so I have 15 months to get the cobra finished so I can drive it to my own wedding - I'd best get the finger out...
Old 20-08-07, 10:17 PM
slogger's Avatar
Originally Posted by CeeJay View Post
Hi All
.........................rv8 anchor?
CeeJay.
Anchor.....anchor.....Ha hahahah. Thats a fishing weight!!
Hope you get the springs sorted. Cant help but mine is sitting 2.5" too high if that is any consolation, but an easy fix.
Ian DAX 454 Chevy
Old 21-08-07, 07:14 AM
kevchard's Avatar
I personally would leave it high for the SVA and get it sorted afterwards.
My headlights were borderline with 'monster truck' styling approach.
Kevin
PS We went for the strongest possible springs on the front. Very Heavy Duty corty ones.
I will think of the name of the company later, cost about £20 per spring.
Kevin & Helen
DMS Venom Viper
Granada Cosworth 2.9V6 BOA
SVA passed Aug 07
Old 21-08-07, 08:45 PM
CeeJay's Avatar
It may only be a fishing weight when compared to a chevy smallblock but as the poor sap who had to move the bloody engine by myself on a wooden trolley over 100 feet of partially frozen grass (back in december) it was flipping heavy enough! I dont know how you chevy and ford guys move your engines about! You must all be related to popeye, as I almost gave myself a hernia with just 400 pounds of weight to move...
Wheres me can of spinach?
CeeJay
Old 21-08-07, 08:48 PM
CeeJay's Avatar
Kevin
Thanks for the advice Kevin (I thought you'd be out driving your cobra now thats its sva'd - what you doing indoors?), but I'd like to get the car down to the correct height just now so that I can make sure the body lines up correctly with the wheels - I think that this may be my next big issue...
CeeJay
Old 21-08-07, 08:52 PM
slogger's Avatar
CeeJay
Mines a Big Block. All 680lbs of it. Engine crane and help from a mate and his lovely 22yr old female blond assistant got it moved and in the car.
Gareth08 takes the p out of my 'Boat Anchor' but I just found your statement funny. I had a RV8 and life was so much easier.
Just poking fun.
Ian DAX 454 Chevy
Old 22-08-07, 05:53 AM
CeeJay's Avatar
Smile
Just poking fun.
Knew how you meant it mate - I'm just genuinly amaxed that you guys can man-handle such weights!
CeeJay
Old 22-08-07, 07:11 AM
kevchard's Avatar
CeeJay
I'm still waiting for DVLA inspection, so can't drive it yet .
Anyway i am still fitting windscreen and heater etc.
Glad to hear you are cracking on with yours.
Thought you were in India tho?
Kevin
Kevin & Helen
DMS Venom Viper
SVA passed Aug 07
Old 22-08-07, 06:27 PM
CeeJay's Avatar
Kevin
I've been back about a week - and very glad I am to be home! Your sva pass has given me the kick up the arse I required to get back to it!
CeeJay.
Old 22-08-07, 11:33 PM
Hi CJ
What exact spec Sierra have you got on the back?
I know this has been covered a bit but to recap,
Rear spring weights apparently need fuel and a person to set heights...
I got a lowering kit from halfords (not recommended!!) and these give me good unladen heights (spring specs were -45mm). I'm a bit away from fuelling up the old girl so the other bit will wait. These are tending to move about when the wheels are off the ground but as I've the estate set up the shock traps the spring.
I took them back off for now as they leave the rear wheels at 30 - 40 degrees off the vertical and I got the fear!!
Turns out that metal wedges can be machined up to counter act this but I'm not sure how/where they go on. Somewhere between the hub carrier and the frame I gather...
As far as I remember the manual recommends that you cut a turn off the fat end of the springs on the rear and put them back on. having played about with it I think this should actually do the trick! Give it a go they're cheap to replace.
I'll check later (eh..) but I've either 280 or 380lbs a side on 8 1/2" springs on avo coil overs on the fronts (sierra+RV. This gives me about 25mm travel on the shock after the arch hits the tyre!! Can't say how this handles thou!
HTH
Declan
Dizzy Heights blip General Tech Tips & Questions 15 31-10-06 08:22 PM
SVA Light Heights Grease Monkey General Tech Tips & Questions 4 24-03-05 06:27 PM
Spring Rates gwak76 Pilgrim Sumo Technical Questions 12 14-01-05 09:05 PM
valve heights adyv8 Pilgrim Sumo Technical Questions 0 14-04-04 10:17 PM
spring lbs plz MARTIN123 General Tech Tips & Questions 2 05-09-03 08:56 AM
