Old 13-10-07, 07:51 PM
steamyrotter's Avatar
Serial Complicator
I have actually done some more!!
Hi all
After a protracted period of not doing anything to it, I have once again attacked the jolly ol fibreglass.
Admittedly it appears that I managed to get more on my arms than on the car but things are now progressing.
Jobs done today..
Glassed in the Boot and Rear wheel arches.
Fitted the battery tray in the front (Even though the batt is going in the boot!) and glassed it in.
Filled up many holes in the footwells and it appears to be hole free (ish!!)
However now the bleedin thing has bitten me back.
Thought the front wheels would be OK in the arches, although they are slightly closer to the rear than the front. Fitted the wheels on "backwards" to fill out the arches and proved that which I suspected.. Partial lock and the wheels hit the arches at the rear......
Go on kev, you can say it....................................
Now need to wait until I can affford the wheels before I cut the front wings up. bah...
However tomorrows job is to start on the heater modification and installation then maybe struggle like heck with the doors.
Dash is looking a little more promising..
Now have all the instruments and awaiting the buttons and a couple of warning lamps then I can have a bash at that!!!
Any one got any spare lamp holders for a smiths speedo & rev counter? (looks like clip in jobs)
Oh well time for a cuppa me thinks..
Dean.
Old 13-10-07, 08:21 PM
Club Sec/Rep Liason
"Any one got any spare lamp holders for a smiths speedo & rev counter? (looks like clip in jobs)"
Dean. Are they the metal bodied ones with just a hole in the back for the lampholder? If so i've got some Jag ones that might fit
AK 427 351C T5wc
Old 13-10-07, 08:26 PM
Serial Complicator
That's the ones Chris.
You know at this rate Most of this car will be supplied by you!!!
Dean.
Old 13-10-07, 09:21 PM
kevchard's Avatar
Hi Dean
I'm glad to see your enthuisamn return with a vengence. You can use the tie rods to move the whells back and forth in the chassis to get your wheel postion more central.
Keep up the good work.
Kevin
Kevin & Helen
DMS Venom Viper
Granada Cosworth 2.9V6 BOA
SVA passed Aug 07
Old 13-10-07, 09:34 PM
Club Sec/Rep Liason
Mostly held together with parcel tape then
I've just measured the holes and they are just short of 16mm - 5/8" Pm me your address again if they are any use
AK 427 351C T5wc
Old 14-10-07, 10:31 PM
Serial Complicator
Kev.
You are right there.. Forgot about that.
Will have a play next week when i manage to scrape the resin off my fingers.
Chris.
I'll measure up and let you know. Cheers
(you haven't got any for the 2" gauges as well do you?? Bit cheeky I know!)
You obviously have been peeking to know the amount of tape I have used....
Managed to convert an escort mk2 heater box to fit in the hole.
Rather chuffed with that. Just need to glass it, seal a few holes then make some brackets. and wire it. Would you believe that is something I forgot to put in the loom!!!! Berk.. might end up being only a single speed set up me thinks. Having said that I suppose I'd better test it first
Podged the doors on to see if they were in the correct ball park.
They appear to be in the next county.. Looks like some major surgery needed at some point to make them fit, but that can wait. Still need to wait for the glass to fully harden before I cut the fillets out.
Fuel tank, gear knob and suspension system parts in manufacture now so should get them soon. Then I can stop using the jerry can for fuel. Always a bit worried the fact it was sat between the inner two exhaust pipes whilst trying it. Only needed the odd backfire to liven things up.
Right now to search for Dash layouts to see what I like.
More to come.
Dean.
Old 14-10-07, 10:50 PM
Club Sec/Rep Liason
"Chris.
You obviously have been peeking to know the amount of tape I have used...."
Full Set Mate And if you need any more tape? I've still got half a box!
AK 427 351C T5wc
Old 15-10-07, 08:55 AM
kevchard's Avatar
Hi Dean
No wonder your build has only come to £1.50 so far, you have scabbed all the electrical bits from one source, all the mechanical bits from your 'in production' mate and all the other bits from Chris .
The tie bars do affect the handling, but from the corty club you can probably find out what centres are supposed to be between front and rear wheels.
Also size and profile of tyres make a huge difference between wheels hitting or missing arches.
Keep up the progress.
Kevin
Kevin & Helen
DMS Venom Viper
SVA passed Aug 07
Old 15-10-07, 08:40 PM
Serial Complicator
He is always up for a challenge..
For which I never disappoint!!
Slightly (but not much) more than £1.50 spent...(probably half of what you have spent sofar? but then possibly not as much as you spent in the first place????)
The pushbuttons (9 off Stainless jobbies 6 momentary, 3 latching) came to £28
Mind that's not counting the Start Stop button which is a one off design which is either going to be ally or brass depending on the availability of the material.......watch this space........
Dean.
