Old 19-01-08, 03:48 PM
ADRIAN BRAYSHAW's Avatar
Rad To Use
Hi, Anyone Used V8 Rover In Sierra Viper Which Rad Did You Use And Did As Sugested By Build Manual Dose It Work At An Angle
Thanks Adrian
IF LIFE IS LIKE A BOX OF CHOCOLATES, WHY DO I ALWAYS GET THE COFFEE CREAMS ?
Old 19-01-08, 04:11 PM
Sidecarbod's Avatar
Thanks Adrian
The one used in a Pilgrim is a 2 litre (or 2.3 not sure) sierra diesel one turned upside down. It usually is mounted just off vertical.
Some people have has issues with this rad but then again loads of people have found it to be perfectly OK. (Even with a SBC lump).
Graham (chedz) has a diagram of how it's setup, you could PM him for it.
HTH,
Pete
Old 19-01-08, 04:22 PM
Rad To Use
Thanks For That, I Have Heard People Have Had Probs With Rover V8 Overheating In The Past So I What To Avoid This. I Bought A New Water Pump And Im Not Afraid To Buy A New Rad But Would Like One To Fit If Theres One Out There Once Again Thank You For Your Time And Knowledge Adrian.
Old 19-01-08, 04:43 PM
Sidecarbod's Avatar
It weird why some people have problems and others don't.
I'm running a stage III 3.5 lump that hopefully knocks out 230 ish BHP and it never overheats. (It probably will now that I've said that!)
I run with the crappy twin fan setup that Pilgrim supplied and it's been OK.
My stat is a fairly cool one at 74 degrees but this ain't a bad thing (Read Des Hammill's book and you see what I mean).
My temp hovers around 75-80 odd degrees, going up to 85 before tha fans kick in. (I have a slightly higher than standard thermostatic fan switch supplied by Burtons Racing).
I think that the rad is OK, when people have issues is due to ther factors such as expansion tank issues, rad cap issues, air stuck in the system, etc.
Pete
Old 19-01-08, 08:29 PM
steamyrotter's Avatar
Serial Complicator
Adrian
Most common is the sierra 2.3 diesel rad.
I am using the sierra 4x4 rad with twin fans
not actually driven it yet but running it at standstill and it doesn't get that warm.
You need to get it as far upright as you can to aid natural cooling but a slight lean is not a problem, and most times a necessity, to get it to fit.
cheers
Dean.
Old 20-01-08, 01:21 PM
dolphinboy400's Avatar
the rad in the car at the moment is a granny rad, if that helps
Danny
L&R Ram 3.9 RV8 - in need of some love
Old 20-01-08, 08:42 PM
Angry Rad
Sadly I Let The Rad Go To The Bloke That Bought The Engine
Old 20-01-08, 10:10 PM
ahh fair play mate I will let you know what rad i got in mine when i get it but that may be too late, it's got a 3.9 RV8 that has been modified but the rad looked standard. Should have it by the end of feb, but i'll keep checking to see if you sort the problem as these boys on here know a hell of alot more than me
Danny
Old 25-01-08, 08:30 AM
Iain's Avatar
Herd member
I wish I could remember the details on my Rad. It was custom made for the car and we got a discount because there were three people buying but sadly I didn't do the organising. All I know is that it's a big bugger! I've tried to mount it as vertical as I can as I believe that to be the best way to get air through. I'll let you know how well it works when (if) summer comes!
If you want me to try and get the details of my rad then PM me or reply here and I'll see what I can do. If you want pics of what I did then just ask!
Cheers...
Iain
http://www.fake-snake.co.uk/
Classic Replicas Viper
SVA'd Nov 2007
Old 25-01-08, 06:28 PM
viperjim's Avatar
hiya iain , i`d like to see some pics of the rad if you dont mind , not a milion miles from fitting mine now , cheers jim
