| Viper Engine Mounts Hi Guys I know theres a few of you out there who have Vipers with Rover V8's installed. Can I ask you what engine brackets you're using? The set that came with my car are junk (Badly cut about, dont fit and rely on the engine mounts being fitted the wrong way!). See the following link for snapshots: RV8 Engine Brackets I have bought a set of SD1 brackets but I am concerned about fouling the steering column - any help you guys could provide would be gratefully received as I'm becoming concerned about this! Regards Craig. P.s Some holiday this is turning out to be!
__________________ Got engaged on xmas day so I have 15 months to get the cobra finished so I can drive it to my own wedding - I'd best get the finger out... |
| Quote:
Hope this helps
__________________ Leo Sinclair Some cause happiness wherever they go; others, whenever they go. DMS Venom, Rover 4:6, Jaguar, Mega-Squirt, MSD, Eaton M112 |
| Quote:
CeeJay.
| Hi Ceej. Sorry for not picking up on this earlier..... (I am slacking Kev!!) Modified 1986 RR mounts used upside down as per photos attached (will admit to only having one supplied with the engine and my mate (Again) made the mirror image for the other side. Note that these were designed for not a lot of movement as I had to drop the engine sufficiently to clear the bonnet but high enough to miss the front cross member!! when running there was minimal vibration through the chassis, but nothing to worry about. This is my interpretation of mounting system and i do not claim it to be correct or suitable for all installs........ However it took a long time to sort it!!!
| Craig picture attached, you can see how tight it hugs the block, rubber mount bolts onto the flat plate then two small brackets need to be made up with two holes in to take the rubber mount and welded to chassis if you have the Jag chassis they work out the right width for the chassis. The SD1 metal brackets are to long and need to be cut down, but even then the engine sits a little high. Steamy's idea is okay & strong but I will think you will find this method is a lot neater. Best of luck
| Quote:
Thanks Leo - I'm surprised how close to the block the TR8 Brackets are compared with the SD1's. Many thanks to all who replied and I will order up the TR8 Brackets this afternoon. Anybody want to buy an unused set of SD1 Brackets? Just bought them from Dave Ellis for £30 - yours for £25 plus delivery! CeeJay.
| Leo, did you have to alter the TR8 Bracket at all to make it fit? I just received my TR8 Brackets from Rimmers this morning but when I offered them up to the engine only two of the three holes lined up - I'd have to alter the top part of the bracket if I want them to fit... I'm beginning to hate this car... CeeJay.
| Quote:
| engine mounts??? | drimman | AK Technical Questions | 4 | 02-04-05 05:38 AM |
| Engine Mounts? | steamyrotter | General Tech Tips & Questions | 0 | 28-03-05 07:59 PM |
| Engine Mounts | PaulF | General Tech Tips & Questions | 4 | 05-01-05 09:31 PM |
| RV8 ENGINE MOUNTS | adyv8 | Pilgrim Sumo Technical Questions | 6 | 09-02-04 07:58 AM |
| RV8 engine mounts | dave jenkins | Pilgrim Sumo Technical Questions | 4 | 01-05-03 10:02 AM |
