Results 1 to 10 of 13
Thread: What Coolant
    Dec 2019
    amersham
    265
    What Coolant
    Its about time i filled up my new build with some coolant, its a Chevy small block, cast iron head and block. With quite a few types on the market now , some water based , some not water based, its a case of choosing a coolant for an engine which is most probably not going to be started on a regular basis.
    Any recommendations welcome.
    Mar 2008
    Coventry
    2,382
    You want the blue stuff
    https://www.eurocarparts.com/p/tripl...4aAp2uEALw_wcB like this
    AK, on the road Oct 2012
    Shropshire
    1,251
    Blue antifreeze, 50:50 with DI water.
    I buy online from Smith Alan in 20 litre drums and replace every two years, no issues in decades on all of my vehicles.
    Pink stuff will cause rust and sludge no end with our older engines and mixtures of brass, aluminium and cast iron.
    Stu
    _________________________________________
    Hawk 289 Powered by a FORD 289
    My Gallery http://www.cobraclub.com/gallery/sho...wk-289/cat/500
    1,671
    Quote Originally Posted by seph View Post
    I use blue antifreeze flush out every two years with cast heads and back flush through bottom hose.
    Allows use Carparts4less as they are always cheaper for the same product. The are same company as Europarts !
    I always search on Europarts first as they have a better search facility on there site then paste the product code into the search at Carparts4less.
    https://www.carparts4less.co.uk/p/tr...5ltr-523770471
    Over £15 so free delivery.
    John Desz
    Essex & Herts Area Rep. UKCC
    Events posted and meeting updates follow Face Book.
    https://www.facebook.com/groups/170236225077355
    Dec 2019
    amersham
    265
    Looks like its the blue stuff then, i will get some on order.
    Mar 2020
    Norfolk
    40
    3,012
    what about those with ally heads and cast block - what would you suggest then?
    May 2012
    near Thame
    212
    I've used this stuff in mine 73 Chevy block with Ali heads did a good bit of checking first that it'd be ok.
    Greg
    Edit now with link
    https://www.opieoils.co.uk/p-92090-motul-inugel-classic-ready-to-use-coolant-antifreeze.aspx
    Dec 2019
    amersham
    265
    OK So got some blue stuff and have put 5 litres in and its barely registering in the header tank, so how much more do i put in, I do not want to overfill it so i reckon about half way up the header tank should be ok ?. The engine is yet to run so there may be a level drop when the engine is running.
    Any comments/recommendations appreciated.
    Mar 2008
    Coventry
    2,382
    Quote Originally Posted by methoni View Post
    It will take a lot more than 5 litres more like 10
