Results 1 to 10 of 28
    Jul 2009
    Swanmore
    13
    Cool RAM Cobra for sale
    Unfortunately time for the Cobra to go after knowing the car for many years and owning it for 5!
    So here's a few details:
    Model: RAM Cobra (LR Roadsters)
    Engine: 350Cu in (5736cc) Chevy, Re-bored +.030
    Fitted with TRW forged pistons.
    Crank – reground, tuftrited & balanced, ARP main studs & rod bolts.
    Edelbrock Performer Plus cam, lifters, true-roller timing set & high vol oil pump.
    Torker II manifold with Edelbrock carb, Cloyes mini torque starter.
    Mallory electronic distributer.
    Edelbrock chrome valve covers, air filter, alternator, timing cover & sump.
    Heads: Edelbrock Performer RPM Aluminium heads.
    2.02” Inlet & 1.625” Exhaust valves, screw-in rocker studs.
    Competition Cams, roller rockers and hardened push rods.
    Gearbox: Tremec TR3550 TKO 5 speed with kevlar/composite dual layer clutch.
    Hayes 30lb flywheel.
    Front Axle: Jaguar XJ12. 12” vented discs, 4 pot callipers.
    Rear Axle: Jaguar XJ12. Limited slip diff, 11” drilled discs.
    Built using 1970 Jaguar donor, correctly registered as LR Roadsters
    Classic "H" plate so tax exempt.
    Built by a very reputable chap from the Victory Wheelers Club in 1990, I am only the second owner since this time.
    I have a full pictorial history of the build including pretty much every receipt going!
    Have a colour matching tonneau cover that I tend to use if needed as it zips down the middle so can open one side only. I do have a roof but to be honest it is not very good and I have never driven far with it on.
    Has classic rear exhausts which also allows extra legroom for the driver. At 6'2" I struggle to fit in some other cobras that I looked at in the past; this has the bonus of plenty of leg room.
    It's a great car that has that real classic look and sound to always turn heads; not concourse as I use it but a very honest example, well built and with all the right bits. Being pedantic there are the normal few marks around the body and ideally currently needs a small new piece of carpet in the driver foot well, rest is good. To be honest, I have mats so have not got around to sorting that bit as yet.
    Photo of engine bay is an old picture but still looks the same apart from I changed the distributer from Accel to Mallory.
    Had the car tuned on a rolling road in 2012 and printout shows a healthy 349.458BHP so certainly no slouch!!
    Price: £22,500
    Hope I have included all of the relevant info, please do email me if you want to know anything else.
    Buckingham
    1,609
    That's a lot of car for the money. Won't be for sale for long!
    good luck.
    Rog
    AK 427 SC now sold. New ride is a 57 Chevy Bel Air Big Block 454
    Feb 2009
    Southampton
    13
    pm sent - look forward to hearing from you.
    regards
    Jul 2009
    Swanmore
    13
    Quote Originally Posted by T&T Cobs View Post
    regards
    Thanks; hopefully you have received a message back
    Mark
    Southwest, Somerset, U.K.
    37
    3,317
    Will on also
    37
    3,317
    Pm rather.
    May 2015
    Cambridgeshire
    65
    4
    PM sent - looking forward to hearing from you
    Essex, UK
    4,122
    Is the car still available? Got a phone number if so?
    Simon
    May 2013
    Essex
    31
    Car now on Total Headturners for a fiver under £30k!!
    Essex, UK
    4,122
    JEEEEZ, that's me out then!
