Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
  1. #41
    Jun 2015
    Lancashire
    39
    Thank for all your efforts on this.
    I'll start tracing back from the relays and see if i can manage to get things worked out.
  2. #42
    Jun 2015
    Lancashire
    39
    Ok managed to get the wash/wipe working fine bar the self park as I'm unsure of the colour?
    Just the headlight switch to think about and it should be ready to go.
  3. #43
    Lanarks
    65
    692
    I used BL Mini wiper column switch on my Corsa C EPAS column
    Advantage is the wiring colours all match the wiper motor.
    I originally had the correct toggle switch fitted.
    My easy to read wiring diagrams help me with what goes where instead of those spaghetti efforts
    - so keep this one a secret.
  4. #44
    Jun 2015
    Lancashire
    39
    Superb, thanks a million for the drawing. Green/Yellow......probably the only colour i didn't try try last night. D'oh
  5. #45
    1,632
    The self park relies on a constant voltage to pin 4 of your motor Light/ Green and earth Black return Motor pin 1. If the earth from the motor is not connector or pin 1 the self park will not work.
    Pin 4 could be a different colour so I would check on the plug position. The wiper motor pin out again might be different on your plug.
    Plug
    1
    3 2
    5 4
    1 - Earth------- Black ( check motor has a good earth)
    2 - +ve feed---- Brown/slate
    3 - Fast Speed --Blue/Green
    4 - Park ------Light/Green ( This goes to fuse 8 also)
    5- Slow Speed-- Red/Green
