Results 1 to 9 of 9
    Nov 2004
    Portsmouth, Hampshire
    469
    Tonneau template or loan in Hampshire
    Now my car is on the road and behaving itself Im thinking about paint and finishing touches. Im not bothering with a roof but do want to do a tonneau.
    Wondering if there is a standard template for them or if anyone around south Hampshire might be willing to lend me theirs so I could take a rough template of where it sits ? I have found a place in Waterlooville who can make it for me.
    My car is an SRV8 with a full roll hoop but I expect most kits like Dax, AK are going to be relatively similar.
    9,533
    Quote Originally Posted by pevans View Post
    They are all different. I tried a Sumo Pilgrim on the Crendon - it was too short by several inches. Roll bar placement and steering wheel position are also different on different cars.
    Its not difficult to make a template from card or stiff paper, but when I looked, most trimmers quoted the same (about £4-500) whether it was a supplied template or you dropped off the car with them for fitting.
    Nov 2004
    469
    Thanks Kevin, I guess I am looking for what is 'right' in terms of shape and clip locations. Im sure I saw a drawing in the past but cant find anything on line.
    9,533
    here yago:
    http://www.clubcobra.com/forums/orig...7-cobra-2.html
    Going to get one myself eventually, but it won't be entirely 'period correct'...not that 427S/Cs ever had them fitted anyway , as it will stop before the backleg of the rollover hoop.
    Nov 2004
    469
    Thanks for the link, I have ended up taking some of that and searching images on the internet. Having looked the only thing to consider would be a soft top for the rear stud locations but as I am not bothering with one it doesnt really matter. I have also found a local trimmer who will make one from scratch with a zip down the centre for £500 which sounds reasonable for a one off.
    Jan 2008
    Basingstoke
    1,160
    Off the shelf from Pilgrim or Ak is probably 400 so £500 isnt the worst price in the world if its from scratch...
    Although buying the fabric and cutting it to size yourself might save a few quid - makes it simpler job for him just to edge trim & add zip & steering wheel section.
    9,533
    yup, that does seem to be the going rate.
    If you plan to drive the car with it fitted, you might like to specify a couple of straps in matching matereil with popper or velco fitting so you can roll the drivers side back for driving in a neat 'swiss roll', and just unroll and pull the zip when leaving the car.
    Some people have had a bad experience with that driving style with flapping causing the tonneau to rip, or damage the lift-a-dot. I never had a problem, but I used press stud poppers.
    Nov 2004
    469
    good point, Im sure they will do that if I ask.
    Nov 2004
    64
    189
    I have a tonneau cover on my RAM if you want to use it as a template. RAM and SRV8's are very similar in dimensions.
