Results 1 to 10 of 16
    Feb 2006
    Somerset
    1,093
    Front Spring Change
    Hi
    Its been a while since I built the Cobra (a long while!) and apart from general maintenance I haven't done much spanner work, so please bare with me!! Since replacing my RV8 with a 350 Ford Stroker and Tremec gearbox, the car has been a bit heavy on the front as you can imagine. The ride height is to low as the springs aren't rated high enough. I have been in touch with Andy Burrows and he is sending me some up-rated springs to fit as a replacement.
    My questions are as follow:-
    Will it be possible to change the springs without taking the shocks completely off the car (undo at the top maybe but leave the bottom attached?) I have limited space since moving house so the easier it is for me the better!!
    Will the spring need compressing or do I just wind the support plate right down to the bottom before I take them off?
    Lastly, the Pro Tech shocks have a knurled knob for damper adjustment. How do I know what the setting should be once the new springs are on?
    Many thanks
    GD427 Mk4. Chassis No J0258
    Ford 347ci Stroker - AFR 185 heads - Holley 670 - KB Pistons - Lunati "Voodoo" 272/280 Cam - 451 bhp/441 lbft.
    3,836
    Yep, that will work.
    Jack car up
    Remove wheel
    Wind spring base all the way down
    undo top shock mount
    Swing shock out
    Prise out top collar and lift spring off.
    As for the dampers, I start at the softest and work my way up until it’s too hard....then back off 3 clicks (highly scientific!)
    Rgds
    GD J1M
    Feb 2006
    Somerset
    1,093
    Perfect!!
    Thanks Jim
    3,836
    2nd thoughts, no it won’t
    Just nipped out to the garage and checked....no chance, top arms won’t allow enough movement
    Soz
    GD J1M
    Feb 2006
    Somerset
    1,093
    Must admit I looked at mine and did wonder. Ok they'll have to come off then. Hopefully shouldn't be to difficult!
    Thanks Jim
    May 2008
    Cambridge
    150
    I replaced my front shocks not that long ago. As I recall, I did "need" spring compressors, as the spring was still under a bit of compression even with the base wound all the way down. I figured it was safer, but there was not much compresssion left, maybe about 1cm...
    Richard
    GD Mk3 LS6
    4,837
    I meant to say something like that - it highly depends on the 'free length' of your spring vs shocks.. on the GAZ shocks Dax supplied for my DeDion the fronts needed no compressors to assemble (just unwind the lower collar, remove the top collars and the spring slides off/on) but the rear needed compressors - or in my case, due to the small diameter of the spring, ratchet straps*, to compress the spring enough to get the top collars on.
    *Not recommended, do at your own risk etc, there is a lot of stored energy in a suspension spring!
    Feb 2006
    Somerset
    1,093
    Just to round the thread up, I changed the springs today without to much drama. I had to remove the shocks to change the springs and the only 'fiddly' bit was taking the top collar off to remove the springs and then putting it back once the new springs were fitted.
    Thanks for all responses
    9,645
    Glad to hear you got it all sorted, let us know what you fitted and how it is once you’ve had a chance to go out and drive it a bit.
    Feb 2006
    Somerset
    1,093
    With new springs fitted and a few miles under my belt, I have a question! Even though the springs are wound up exactly the same on each side, the offside front sits lower than the front near side. Would it be Ok in a drive geometey sense to wind up the offside a bit more than the near side? I could try it and see but thought I would pose the question first to maybe save me the job!
