Results 1 to 8 of 8
    2,501
    Car trailer plans
    I don't know anything about the company but I like the look of this trailer for Cobras. The price includes DXF files for laser cutting so quite a lot of design work saved.
    https://fabplans.com/products/air-bag-car-trailer
    4,737
    Aside from having to find somewhere to store the damn thing (hard enough for my little Erde!) .. don't trailer/caravan chassis have to be type approved these days?
    I have seen a video of a bagged car trailer like that though - very neat trick and handy for low cars like ours, for sure!
    Oct 2017
    Oxford
    1,153
    Yep trailers have go through testing. So building one of those as a one off would need an IVA style test
    Classic Replica Viper IVA passed 25th March 2021
    3,816
    I thought airbags needed to operate in a single plane? Those look like they are forced into an arc to rise the trailer.
    GD J1M
    May 2012
    near Thame
    212
    I'm fairly sure happy Jim is right here, even pillow bags have a limit to the angular miss alignment they can cope with.
    If they're bolted in at each end and extend in an arc they could rub and wear prematurely, might be worth a check on that.
    4,737
    I did a bit of reading and Firestone quote up to 30º misalignment and 2" plane misalignment uncompressed but must be 0º and 0" when compressed.. less than ideal but I imagine they'd be OK for the kind of miles the kind of trailer queen that'll live on a trailer like this will do
    I don't fancy getting a trailer someone else designed through an IVA test though! Imagine all the sharp edges...
    Nov 2006
    Shropshire/Wales Border
    50
    6,075
    £70 for the test and it doesn't look terribly onerous. Nothing like the car test. TBH, if you've built it properly and used a bit of common sense its going to pass.
    I built one with a friend a few years back as we both had low ground clearance cars that normal trailer struggle with. We put about £700 into it, inc hot dip galvanising. They end up fairly wide with the wheels out of the side to get the low level. Not sure why you need airbags. They do take a bit of storage, which is why we sold ours. Have regretted it ever since, usual story, you don't realise how much you use it until its gone.
    Lloyd B
    Nov 2003
    West Midlands UK.
    3,034
    Trailers for Cobra transportation are so last year.
    This is what you need for a Cobra hauler.
    https://www.youtube.com/watch?v=iV-2hIDP7kg
    Tony
