Results 1 to 7 of 7
    Mar 2020
    Norfolk
    38
    SBC - head bolt cleaning tap
    Hi there,
    I'm replacing my cylinder heads on my 350 SBC and want to clean the thread for the head bolts.
    I understand that the thread is 7/16"-14
    Any idea where I could get one of these in the UK (or something similar) https://www.summitracing.com/parts/arp-911-0004
    I understand these 'cleaning' taps are less harsh them a proper tap.
    Or perhaps someone could lend me one?
    Any help appreciated - bear in mind - I'm a muppet.
    Phil
    10,280
    I'm sure you'll find one on Ebay.
    4,737
    "Thread chaser" is what you're looking for and they seem to be awfully hard to find in the UK in imperial sizes, now. If you don't want to use a 7/16 UNC tap, though, you can take a bolt and cut four lengthwise grooves into the threads (see pictures of a real thread chaser here: https://mechanicalmalarkey.com/2018/...he-difference/) - it'll wear out quicker than a chaser and isn't as hard, but it'll clean out rust & gunk with no risk to the threads themselves.
    If it binds, then use a tap instead, because there's a galled thread that needs re-cutting.
    I've always tended to use a tap personally, though I realise it isn't ideal
    567
    I always use a 7/16 UNC tap. Surprising how much crap can come out!
    Nov 2006
    Shropshire/Wales Border
    50
    6,075
    As above, just run a tap down the threads. Good practice for any thread in your rebuild.
    Lloyd B
    Mar 2020
    Norfolk
    38
    Well I found the ARP tap in the UK https://shop.arrowprecision.com/7-16...aning-tap.html - but £60!!! I think I'll just get a regular one
    Maldon Essex
    522
    I have never had a problem using a normal tap for these jobs, just make sure you get it started properly and use some oil. I have always used a plug tap or No3 tap as its not for starting the thread cutting process so will be far less able to chew up your existing thread and just follow it.
