Results 1 to 8 of 8
    Nov 2020
    Brighton
    11
    What spark plug leads and boots?
    Afternoon All, my Mike Huddart 351w engine has Malory 8mm silicon spark plug leads and 90 degree boots, just wondering if anyone could recommend a possibly better set up? Thanks for any pointers.
    1,584
    Your leads sound good quality. 8mm is enough for a good set up. You say 90 at the dis end ? Having straights at the spark plug end keeps you away from the headers on the ignition side a MSD 6Al with blaster coil and contact less points is a strong set up.
    10,278
    From personal experience I've always found that 45 degree boots at the plug end are correct for most small block Fords.
    90 degree at the dizzy cap male or female depending on your cap.
    8mm Mallory leads should be fine.
    Nov 2020
    Brighton
    11
    Thanks for the replies guys, looking closer at my setup it looks like I have a roadcraft distributor. I like the idea of a MSD 6AL and blaster coil which I assume would not work with my distributor?, so any suggestions as to which distributor to go for? Thanks again.
    1,584
    Install a Pertronics into your standard distributor and hook in a MSD 6AL.
    564
    Got to love MSD! No reason why it wouldn’t work with the dizzy you have, I believe they work in most scenarios.
    Before you buy, look at their range. I have just bought the digital programmable one for my GT40. Not run it yet so can’t comment but feedback is good. I intend to lock out the dizzy advance and just run the advance through the MSD box. They come with a little app where you tune the timing on your laptop. If it doesn’t work I have the MSD dizzy with changeable springs so will tune that way instead!
    Btw, I bought my last 45 degree boots from Raceparts UK in Wallingford.
    Nov 2020
    Brighton
    11
    Thanks again for all the info guys, it's been many years since I last delved into the oily bits. I'll take another look at my distributor tomorrow but I'm sure it's a HEI. As Jon said I'll swap the module for a Pertronix ignitor and hook that up to a MSD 6AL. I've ordered a new set of leads with 135 degree boots. Just one more Q, what rev limit are you setting on the MSD?
    9,633
    Quote Originally Posted by badhorse View Post
    I used to run a Pertronix with a MSD 6AL and the combination worked great. I have a 351W and the max I would ever rev it to is 6000rpm.
