    Dec 2019
    amersham
    265
    Taper thread sealant
    Can anyone recommend a good taper thread sealant. I have a situation where the heater take off hose connection on my chevy 350 is leaking via the threads, i have used ptfe tape and its still leaking. In theory taper threads should be self sealing but i suspect the thread is slightly undersize hence the problem. A thread sealant that perhaps hardens would be okay.
    2,509
    Just about any thread sealant should do, it's a low pressure system.
    Tapered threads do need thread sealant unless they are 'dry-seal' threads. This is the difference between NPT and NPTF threads - the latter is a dry-seal thread and should not need sealant BUT both the threads must be NPTF for this to work. The Chev heater connections are NPT.
    1,428
    ARP thread sealer works for me, it's resistant to oil, petrol, water Inc antifreeze solution. It's like a paste that goes off but it stays like a firm paste without going rock hard. Memory thinks that they use it on Chevy bolts that thread into the water jacket.
    Lee
    10,353
    PTFE tape works in most situations.
    4,840
    I was going to say the same thing - it's the thickest thread sealer I've used, too. I've used it on the oil temp, water temp and oil pressure fittings (all taper thread, NPT). There's also Loctite 542 and Loctite 577 - I've not used the 542 yet as the ARP stuff seems to do what I need, and I've not used 577 on an engine but have used it on all sorts of other water/air/etc fittings and IIRC it's a yellow goop which doesn't fully set, but doesn't contain PTFE (which the ARP stuff does).
    Dec 2019
    amersham
    265
    Thanks for the replies.
    I think the problem is a cheap aftermarket part that i purchased where the gauge plane diameter of the thread is undersize, this affects the hand tight engagement and also prevents proper sealing when wrench tightened.
    Screwfix sell a thread sealer which i will give a try if that does not work then its a case of ordering a better manufactured part.
